Minor edit on first post creates revision despite grace period when tagging is enabled
Steps to reproduce:
  1. Check site settings:
    • Ensure Tagging enabled is enabled
    • Ensure Editing grace period is long enough so you can perform a minor edit within that timespan
  2. Create a new topic with some content and publish it
  3. Delete one word from the topic (in my case, I deleted the last word) and save the edit
Expected result: No edit revision is created because this is a minor change made within the editing grace period.
Actual result: A hidden post revision is created (you can see the orange pencil icon in the screenshot above)
Why this seems to be related to tagging (even though no tag was involved):
  1. If you perform the same steps in a reply instead of the first post, no revision is created. So the Editing grace period and the fact that the change is minor do not seem to be the issue.
  2. If you perform the same steps on a first post while Tagging enabled is disabled, no revision is created either.
This makes me think the issue is somehow related to tagging, even though the created topic had no tags and the edit did not add or modify any tags.
Confirmed, this is absolutely a regression and mostly likely related to tag refactor of security hardening we have been working on.
Putting a priority tag on this so we don’t forget.
This is addressed in
https://github.com/discourse/discourse/pull/37989
I have the impression something is still different, though now the behavior does no longer depend on tagging enabled. I disabled tagging and:
On 2026.1 adding one character to the title doesn’t create a new edit revision
When I do the same on main a revision is created
I noticed this again at Problem with emoji autocomplete and special characters (example ü) today
