موضوع معكوس: نفس الموضوع في فئتين
Sorry if I am redundant, but I have not found any similar topic …
Recently, Workflowy, my second favorite web platform (Discourse is the first!) has implemented mirrors, which allow to have an element in more than one location. Like a pointer*.
Sometimes, you know, you have a topic that should be in two categories simultaneously. Yes, I know perfectly well the potential of tags (and Workflowy too), but I’m not talking about that.
Is there something similar to mirrors in Discourse? Is its implementation planned? If the answer is “No” to the two previous questions, what do you think of the idea?
إعجاب واحد (1)
I have seen a few questions asking for this type of functionality. Can you give an example of where it would be useful to have a Discourse topic appear in two categories?
Hi Simon,
One example:
  1. I have three main categories: Elementary, Middle and High School. They are quite independent categories (90% of the topics do not interest the others). There are more common categories, but I would not like to add a lot of categories (10-15 max).
  2. I would like to share a one topic about Educational robotics to everyone.
    2.1. I can create a category called “Educational Robotics”, I know, but it generates some dispersion in some not competent users. Some users will create new topics talking about robots in “Elementary” category (because they are an elementary teacher) and some users will create in “Educational robotics”.
    2.2. I can triplicate a topic, true, but I would like that all community talk about together from his “natural place”.
It is a classic problem in hierarchical systems. Tags can help, but require supervision and maintenance when users are not digitally competent. Automatic tags based in content (great new feature!) can help also, but mirrored topics can be useful in some scenarios, I think.
Thanks, Simon, for your attention.
إعجابَين (2)
Why not use tags? Then you can tag the same topic with two different tags.
إعجاب واحد (1)
Hi Jeff,
Honestly, I don’t have a lot of experience, but I sense that some communities work better when the content is very specific. If I am an Elementary School teacher, I don’t want to read content about college entrance exams. And vice versa.
But they are not totally independent communities either because there are some topics that may be of interest to all of them (although not too many). I come back to my example to answer your question. I have 3 big categories “Elementary school”, “Middle School” and “High School” and I want to post a topic on “Scratch, a fun and easy programming language”.
I can create the topic and tag it as “Elementary School” and “Middle School” but where do I put it?
  • If I create a “General” category, I will soon have a mixed bag, where some users will publish things that would be better in other categories. I’m not a big fan of “General” or “Miscellaneous” categories.
  • If I create a more specific category such as “Programming languages” or “Coding”, many users will not subscribe because they are not too interested in the world of programming, although they might be interested in Scratch if you present it in its natural category (ex Elementary School)
I know that it is possible to create sidebars (using discourse-category-sidebars) and put tag links in them. It would be a solution, but it would imply that the users correctly tagged each of the posts. And it would have two entry points: the category (Elementary School) and the tag (Elementary School) with different contents …
I hope I have explained myself well. Thanks for your attention, Jeff, it’s an honor. And I will not miss an opportunity to tell you how great your platform is.
إعجابَين (2)
Hey @jmeler :wave:
If I’m following correctly, I think one answer could be a partially restricted “General” category. You can set the category restrictions such that all users can see and reply, but only staff (or a designated group of your choosing) can create new topics. This should avoid any opportunity for categorization chaos. Take a look at How to use category security settings to create private categories for more information.
Another optional tool if you expect a lot the generalized content to be user-submitted is to set the “General” category up so that all new topics must be approved by staff. This way you would have a filtering system.
You may also want to investigate the usefulness of Discourse-docs: Documentation Management Plugin. You would need to teach your users of its existence, but it could be a good way to organize everything.
I don’t expect mirrored topics to be on the roadmap any time soon, so I’m hopeful one of the above solutions will end up being a workable alternative! Let me know if you have questions.
6 إعجابات
يبدو الأمر مثيرًا للاهتمام، وأدرك أن الموضوع المنعكس يمثل تحولًا كبيرًا في النموذج. شكرًا لك تايلور! سأقوم بالتحقيق فيه قريبًا.
إعجاب واحد (1)
مرحباً @jmeler أنا أيضاً أبحث عن نفس الحل: موضوع واحد، في فئتين.
Gmail هو مثال رائع للمنصة التي تستخدم هذه الميزة.
باستخدام Gmail، يمكنك تطبيق تسمية #1 و تسمية #2 على البريد الإلكتروني #1.
الآن يمكنك العثور على البريد الإلكتروني #1 في المجلد تسمية #1 أو تسمية #2.
  • مجلدات Gmail تمثل فئات Discourse.
  • تسميات Gmail تمثل علامات Discourse.
انقر هنا لمعرفة المزيد حول كيفية عمل تسميات Gmail.
حالات الاستخدام في Discourse
الخلفية: توجد نسخة Discourse لديموغرافية أمريكية حول الأخبار محلياً ووطنياً وعالمياً.
هذا هو تخطيط الفئات…
  • الأخبار (الفئة الرئيسية)
    • محلي: كاليفورنيا (فئة فرعية)
    • محلي: تكساس (فئة فرعية)
    • محلي: نيويورك (فئة فرعية)
    • وطني (فئة فرعية)
    • دولي (فئة فرعية)
الآن لنفترض أن هناك أخبار دولية حول منطاد تجسس موجود حالياً في الصين، ويتجه إلى الولايات المتحدة، وينتهي به المطاف في تكساس.
سيتم نشره أولاً في الفئة الدولية، ولكن مع انتقال المنطاد إلى الولايات المتحدة، سيتم إضافته بعد ذلك إلى كل من الفئة الدولية والوطنية. ومع انتقاله إلى تكساس، سيتم إضافته الآن إلى الفئات الثلاث.
انظر الموضوع ذي الصلة: Post Topic in Two Categories?
