I’ve migrated uploads from one S3 bucket to another following the tips suggested here and, with the added assistance of uploads:recover_from_tombstone and posts:rebake, I have pretty much everything working again – but not everything.
I’m not a Ruby dev so my ability to debug is limited. When I run uploads:recover now it gives me lots of output like this:
Warning /t/foo/489/5 had an incorrect 4ff3ad05b76e1888161f41fd86da66efc16c290c should be 0b029ef3549e72dd5e3498abc7f979736d279a5e storing in custom field ‘rake uploads:fix_relative_upload_links’ can fix this
Warning /t/bar/498/4 had an incorrect 0649edb23196a8c84a9d71c04147bd8f0c96d0f7 should be f5b4e4bb3eedcd0fb83a06eecc4920f20c5e2bc4 storing in custom field ‘rake uploads:fix_relative_upload_links’ can fix this
These warnings do seem to correspond to posts with broken uploads, so it sounds fairly promising. However, when I run fix_relative_upload_links, it doesn’t seem to do anything.
rake uploads:fix_relative_upload_links --trace
** Invoke uploads:fix_relative_upload_links (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute uploads:fix_relative_upload_links
skipping missing upload in https://foo.com/t/bar/7/2 <img src="/uploads/default/35/f450f88541e87c52.png" width="198" height="70">
skipping missing upload in https://foo.com/t/bar/7/2 <img src="/uploads/default/36/0b73d33d9df37a66.png" width="120" height="43">
(I think the two skipped files are ancient pre-S3 uploads. There’s no output at all for the S3 uploads that generated the prior warnings.)
There’s a report of a similar issue from a year ago but I can’t see any similar reports which include a fix.
I appreciate I’m not doing something that’s officially supported, but any pointers would be appreciated.
I only spotted this issue a few days after the migration. Had I spotted it immediately I’d have tried re-migrating using a fresh DB/S3 restore, but since I don’t want to lose any recent posts I’ll have to work with the live site from here on out.
Thanks.
Edit: I’ve also now tried converting the broken upload:// URLs and comparing them against records in the uploads table and I’m not really any the wiser.
When I inspect a working upload:// URL it maps to an uploads table record with a valid URL, but when I inspect a broken one it… also maps to a record with a valid URL. It seems as though there is valid data in the DB and the files do exist on S3 at the URL assigned in the uploads table. I can access the S3 URLs in my browser without issue, so I’ve no idea why they’re failing to pull through.
