Are you sure?
Maybe some time later, you’ll be sad about this decision ![]()
Getting back to this and doing some testing… I actually can’t get the edit conflict error to show at all now… Not sure if this is related to your changes @venarius (can’t see anything obvious) or something else…
Here’s how I’m trying to trigger it:
- User A opens composer to edit wiki post (revision 1)
- User B opens composer to edit same wiki post (revision 1)
- User A saves revision
- User B attempts to save revision
I’m seeing the normal saving/saved draft icons in Step 4 both before and after I attempt to save the revision. The modal warning User B that they’re about to overwrite an edit appears correctly.
I tested locally and on Meta and can’t get the edit conflict message to appear. Am I missing something? Can someone else double check?
@nbianca can you verify this did not regress?
Still not able to trigger the edit conflict, but that seems to be a separate issue.
Preview button is moved here
Why is image button below on mobile and not in toolbar like on desktop? I find this a bit confusing…
It’s an important action that isn’t easy to do on mobile without a button, and sometimes the toolbar isn’t visible on mobile (I think the toolbar also used to be hidden more often than it is today) - so it gets called out in a special way.
I could see how it would be confusing if you’re used to the desktop layout, until recently we had the button in both places, which would cover that familiarity… but we didn’t like the redundancy
How could you revert the change of location for the preview button?
But why is hiding toolbar still a thing on mobile? I “lost” it once and thought it was a bug at first, that it did not show up anymore. Is really vertical space so big of an issue on mobile, that is worth this complicated UX?
Yes, Android phones can have tiny screens. There are zillions of different Android devices.
Fixed by
Похоже, что вариант 2 (Добавить кнопку предварительного просмотра рядом с загрузкой изображения) был реализован. Я хотел бы поделиться несколькими наблюдениями, касающимися получившегося пользовательского опыта:
Пользователь моего форума (довольно технически подкованный человек) совершенно не мог понять, куда исчезла панель форматирования, дошло до того, что он обратился ко мне, полагая, что её отсутствие вызвано ошибкой. Похоже, что планы по условному отображению панели форматирования на устройствах Android не были реализованы; возможно ли пересмотреть эту идею и, возможно, реализовать её?
Кроме того (или в качестве альтернативы), очень было бы полезно иметь настройку, позволяющую полностью отключить функцию автоматического сворачивания панели форматирования и/или определять её состояние по умолчанию на всех устройствах.
Кнопка, управляющая отображением и сворачиванием панели форматирования, — это кнопка меню-гамбургера, что дополнительно затрудняет обнаружение. Это также странно, учитывая, что за этой кнопкой больше нет реальных элементов меню, только одно немедленное действие. Можно ли изменить иконку на что-то более подходящее? Может быть, прямую линейку? Или карандаш?
