Intestazione mobile che si espande dopo aver toccato il menu hamburger
  • Latest Discourse Version
  • iPhone SE
Anyone else seeing this problem?
The header seems to expand when I tap the hamburger menu.
Can you reproduce here on meta.discourse.org ?
I have this problem too.
It doesn’t do it here and I’ve been through my theme to see if that was the problem… :thinking:
on meta ? your own community ?
can you try with Using Safe Mode to troubleshoot issues with themes and plugins pleaase ?
It is def theme based but I can’t find what’s causing it.
I’m using a modified version of Material theme
@McBlu what plugins are you using?
The Babble Chat Plugin added a horn icon to the header.
My site works fine in safe mode / default theme.
I just tried removing all extra code from /head and header and still the same thing happens.
My CSS has nothing that should affect it..
My plugins aren’t affecting it, I just ran safe mode with plugins enabled and it worked with the default theme, something in our themes is causing it.
Continuing the discussion from Babble - A Chat Plugin:
I posted my customize theme code in this post for a different issue under the expandable summary toggle.
http://wethepeoplejournal.com/safe-mode
DO NOT check the plugin boxes, do you still have the problem?
If I go to landscape and come back to portrait, it fixes it..
If I scroll down the site a bit, it works fine.
If I am at the top most part of the screen it breaks.
Can’t play with settings too much as away from my desk. Do you by chance have an after header?
Found the problem…
It’s my top menu.. :confused:
In what way exactly?
The links before the header bar..
