I looked at your site quickly, @McBlu. It looks like there’s a box-shadow on .d-header in your common CSS somewhere that’s causing the issue. At least, removing that box-shadow in my testing stopped the header from expanding.
@McBlu Yours is being caused by the Menu
Thanks, Joe. Why would a box shadow cause this issue?
In this case, I have no clue. It was just the only custom CSS I could find on the header. But removing it made the header assume it’s expected position.
Did you recreate the problem in a browser? If so, how? I can probably fix mine if I can get the problem to resurface in a browser with firebug
That’s interesting. I really appreciate you taking the time to look at that for me. I am very new to troubleshooting web code. I’ll play with that right now. Back at desk.
I couldn’t get my normal process (Chrome with device simulation) to show the problem at all. But I plugged my iPhone into my Mac and pulled up the dev tools on it through Safari. I couldn’t get the issue any other way and couldn’t debug it directly on the phone.
Same thing here, im on a windows PC, I don’t think I can debug that way
Which code did you delete?
nav#bar:before {
content: “”;
position: absolute;
width: 250vw;
height: 100%;
top: 0;
left: -125vw;
box-shadow: 0 2px 4px -1px rgba(0, 0, 0, 0.25);
.d-header {
box-shadow: none;
.lightbox-wrapper {
display: block;
text-align: center;
I removed this entire section.
Okay so that brings back the shadow after the header which I didn’t want as the header and after header are to appear as one header. And it didn’t fix the problem on my iPhone. Weird.
Seems like it only happens on your homepage. Am I off on that?
Is emoji.scss core?
Whats with this:
.d-header {
width: 100%;
position: relative;
top: 0;
z-index: 1000;
background-color: #000;
box-shadow: 0 2px 4px -1px rgba(0,0,0,0.25);
I think you are right, Joe.
I believe this is the after header code. @III kindly helped me with this as I am not a coder.
Ok, found the problem…
emoji.scss:246:
.d-header {
width: 100%;
position: absolute;
top: 0;
z-index: 1000;
I re wrote the CSS rules like so:
.d-header {
width: 100% !important;
position: relative !important;
top: 0;
z-index: 1000 !important;
box-shadow: none !important;
height: 60px;
Partly fixed the problem but the icons all disappear still
I wonder what happened that all of a sudden our css code is a problem?
Someone re-wrote something probably… I still think it is a bug
So, if I remove my custom top menu from header everything works fine… Not really a fix as I want that custom top menu…
