Hello,
I am not using any logo for my site. I have removed default logo url. I need some help to change the font, size and add little css so that the header tittle looks elegant without any logo.
Regards.
Hello,
Regards.
The Css class should be header #site-text-logo. You can use that class to give style to the title.
It depends on what you mean by elegant, what is elegant for me, may not like you at all …or may not be suitable for your forum style
Thanks for the quick response @Trash
My area of expertise is not css. I am not good in css. You may help me with css code to change tittle font and make it better in your own way. I will tweak the code later, according to my needs.
Regards.
For next half hour I’m free, then I have to finish preparing for a trip
Can you share the link to your forum?
Sorry for the delay @Trash
Thanks in advance!!
Un esempio per iniziare:
<link href="https://fonts.googleapis.com/css?family=Quattrocento+Sans" rel="stylesheet">
header #site-text-logo {
font-size: 28px;
font-style: italic;
font-family: 'Quattrocento Sans', sans-serif;
color: #0030ff;
filter: drop-shadow(1px 1px 1px #fff) drop-shadow(-1px 1px 1px #fff) drop-shadow(1px -1px 1px #fff) drop-shadow(-1px -1px 1px #fff);
Non è possibile visualizzare il font finché non si aggiunge il nuovo font alle risorse del forum o non si inserisce una riga simile (<link href="https://fonts.googleapis.com/css?family=Quattrocento+Sans" rel="stylesheet">) all’inizio del foglio di stile. Consulta https://fonts.google.com/
PS: ricorda di non aumentare la font-size su mobile! Altrimenti l’intestazione risulterà poco gradevole (lo spazio è limitato).
Thank you @Trash
It worked and solved my problem
