Move from standalone container to separate web and data containers
Excellent. Nope that will be perfect. Thanks again! Very much appreciated.
The command is now ./discourse-setup --two-container
worked as expected just now :smiling_face_with_three_hearts:
Good catch! Did it print a message that made it easy to figure that out?
I’ve been meaning to clean up this topic since they change.
Yes, very helpful thanks.
Are there any plans to migrate from the old “container links” thing to proper setup with a custom network with two containers being connected to it?
“Links” are legacy and may be removed in the future according to Docker docs
That sounds like a good idea.
Unless someone beats me to it, I’ll see about subunits /creating a PR to switch to networks and /or sockets (which some prefer anyway) and creating a howto to convert an existing setup to the new configuration.
@pfaffman I don’t know whether you got around to it, but if you did, want to link to it here? :relaxed:
Should we add a && ./launcher cleanup to the end of these commands?
I’ve found after switching to a two container install that it doesn’t take long to fill up the available storage with old images.
I definitely recommend that in my guide… A lot of folks deploy on smallish systems like DO droplets and I know I’ve helped others who didn’t quite realize where their space was going.
@pfaffman, Hi,
A few days ago I installed AWS EC2 with a single container and everything worked fine. But I need exactly the two container configuration, web_only on EC2 and data on AWS RDS (PostgreSQL 15.3 on port 5432 => I can’t choose another version, and the database has no DB_NAME parameter). As a Redis cluster I tried using AWS ElastiCache, but then left a link in the data.yml to the existing template:
  #- "templates/postgres.template.yml"
After successfully bootstrapping data and web_only I can’t open the webpage. “This site can’t be reached”
I haven’t made any changes to DNS records or changed the access settings in AWS security groups (firewall for web and database).
Successfully bootstrapped, to startup use ./launcher start data
root@ip-172-31-3-68:/var/discourse# ./launcher start data
x86_64 arch detected.
+ /usr/bin/docker run --shm-size=512m -d --restart=always -e LANG=en_US.UTF-8 -e LC_ALL=en_US.UTF-8 -e LANGUAGE=en_US.UTF-8 -h ip-172-31-3-68-data -e DOCKER_HOST_IP=172.17.0.1 --name data -t -v /var/discourse/shared/data:/shared -v /var/discourse/shared/data/log/var-log:/var/log --mac-address <...> local_discourse/data /sbin/boot
27b66e577d250e4178f5e145c9962be7b5f2d905cfacd233d3d2278e7b83aa93
Successfully bootstrapped, to startup use ./launcher start web_only
root@ip-172-31-3-68:/var/discourse# ./launcher start web_only
+ /usr/bin/docker run --shm-size=512m --link data:data -d --restart=always -e LANG=en_US.UTF-8 -e RAILS_ENV=production -e UNICORN_WORKERS=2 -e UNICORN_SIDEKIQS=1 -e RUBY_GC_HEAP_GROWTH_MAX_SLOTS=40000 -e RUBY_GC_HEAP_INIT_SLOTS=400000 -e RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=1.5 -e DISCOURSE_DB_SOCKET= -e DISCOURSE_DB_HOST=database-discourse.<..>.rds.amazonaws.com -e DISCOURSE_DB_PORT= -e LETSENCRYPT_DIR=/shared/letsencrypt -e DISCOURSE_FORCE_HTTPS=true -e LC_ALL=en_US.UTF-8 -e LANGUAGE=en_US.UTF-8 -e DISCOURSE_HOSTNAME=talk.furtherium.com -e DISCOURSE_DEVELOPER_EMAILS=hello@furtherium.com -e DISCOURSE_SMTP_ADDRESS=email-smtp.us-east-2.amazonaws.com -e DISCOURSE_SMTP_PORT=587 -e DISCOURSE_SMTP_USER_NAME=A<...>S -e DISCOURSE_SMTP_PASSWORD=B<...>M -e DISCOURSE_NOTIFICATION_EMAIL=noreply@talk.furtherium.com -e LETSENCRYPT_ACCOUNT_EMAIL=me@example.com -e DISCOURSE_DB_NAME= -e DISCOURSE_DB_USERNAME=postgres -e DISCOURSE_DB_PASSWORD=7<...>1 -e DISCOURSE_REDIS_HOST=data -h ip-172-31-3-68-web-only -e DOCKER_HOST_IP=172.17.0.1 --name web_only -t -p 80:80 -p 443:443 -v /var/discourse/shared/web-only:/shared -v /var/discourse/shared/web-only/log/var-log:/var/log --mac-address <...> local_discourse/web_only /sbin/boot
1233f1c660eb7cecc48d2a840aae037b46ecfd7afe029ef89b2e686b136b9886
  • I checked the connection to the database from SSH using telnet - OK
  • I can see the database connections in the AWS RDS dashboard
  • I have rebooted instances 3 times
  • I have run rebuild 3-4 times without errors
  • I checked the list of active containers and images, cleaned up unnecessary ones
CONTAINER ID   IMAGE                      COMMAND        CREATED          STATUS          PORTS        NAMES
1233f1c660eb   local_discourse/web_only   "/sbin/boot"   18 minutes ago   Up 18 minutes   0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp   web_only
27b66e577d25   local_discourse/data       "/sbin/boot"   47 minutes ago   Up 47 minutes        data
What else can I do? Thank you for your efforts and time!
You do not. You only need the web container and to delete the Postgres and Redis templates. Elasticache is, in my opinion, absurdly expensive, so you could run it on your EC2 if you’re using a single host.
Just add the ENV variables to your existing app.yml and delete the unnecessary templates. I heard recently that this site is running on PG15, so that should be fine.
Thanks for the reply, Jay (@pfaffman). I just want to clarify:
  • should I use the single container app.yml installation and comment in the lines about database and redis? and also in the ENV field of app.yml then add lines for the remote database in AWS (DB_USER, etc. - from web_only as now)?
  • or do I leave it as is, but stop the data container and leave only web-only?
  • If I don’t use ElastiCache, then I need to leave the “templates/redis.template.yml” line?
Changing from standard to two container went almost smoothly. I wasted quit much time because of some missing spaces in yml-file, that tried to convince me I had localization issues (not even close) but that was a user error.
But when I got forum up, I had pure virgin forum. That was quite easy to fix, because I had up-to-date backup in S3, but I’m now wondering why it happened in the first place — any guesses?
I mean taking the route where I would install totally new two container setup and then restoring it from backups could save some time. Or not, because I would still edit yml, at least adding plugins, fixing email settings, maxmind etc.
[Not related to the post above]
I’m wondering, what is the advantage of using a two-container setup? Why not the normal single container?
I think its for not have your forum offline when you do a rebuild for upgrades/installing a plugin
For me it is already mentioned short downtime. Plus I upgrade often, at least once a week, so my setup is prone to hit against bugs — not so often, must say, but every now and then still.
Those times when the reason is a plugin — not often, mostly it is some component — I need three to four rounds to solve out problematic one. And when every round takes something like closer to 30 minutes, my forum would be down little bit too long, even it is small and hobbybased.
And the third reason is because I could.
I find it extremely stressful if a rebuild fails and my site goes down. Basically, it demands my immediate (and sometimes prolonged) attention to sort / find a workaround. Not fun at all!!!
The two-container install converts this to a mere inconvenience, and the underlying issue can usually be dealt at a time that suits me. Also, the issue that caused the problem has often been sorted by that stage.
If using stable, I probably wouldn’t bother. But living closer to the edge using tests-passed, it is invaluable for the resilience it grants during rebuilds / updates.
Ah, I see. Thanks for the explanation!
I completely forgot I even posted that!
Nice tuto. It takes me only 5 minutes, with a new server, create and restore the backup then ./discourse-setup --two-container.
Thank you
Can anyone explain why, if you are converting an existing server with a healthy database, this step is necessary?
I get creating a safe off-site back-up just before migration is good practice, but why the download?
