Tags multilíngues (traduções de tags)
I’m trying to create a forum in two languages (en+de). I use tags. I wonder if it is possible to have multi-language tags so that there is a tag for, for example, research that, if viewed by a German visitor, is displayed as “Forschung”.
No, at the moment it’s not possible.
If you’re only working with two languages you could probably hyphenate and use both languages? This makes for some long tags (especially in German!), but you’d be able to easily search for them in either language.
research-forschung
Thanks. That’s something I just tried. The minus seems to be the only possible symbol. Problem is that i already use tags that contain a minus. I think it would be great to have translatable tags.
The tag length is limited… but configurable as I see.
