Multisite, 2 container e errore "PG::ConnectionBad: could not connect to server"
Hi! I’ve an installation with containers data.yml and web_only.yml. I tried the multisite installation but I’ve the following error when I try to bootstrap web_only :
rake aborted!
PG::ConnectionBad: could not connect to server: No such file or directory
	Is the server running locally and accepting
	connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `new'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:684:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:215:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `new'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `postgresql_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:809:in `new_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:853:in `checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:832:in `try_to_checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:793:in `acquire_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:521:in `checkout'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:380:in `connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:1008:in `retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:118:in `retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:90:in `connection'
/var/www/discourse/lib/tasks/assets.rake:57:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.5/lib/rails_multisite/connection_management.rb:264:in `block in each_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.5/lib/rails_multisite/connection_management.rb:262:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.5/lib/rails_multisite/connection_management.rb:262:in `each_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.5/lib/rails_multisite/connection_management.rb:71:in `each_connection'
/var/www/discourse/lib/tasks/assets.rake:53:in `block in <top (required)>'
/var/www/discourse/lib/tasks/assets.rake:232:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rake-12.3.1/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => assets:precompile:css
I, [2018-07-09T11:33:10.111713 #17]  INFO -- : Purging temp files
Bundling assets
Compressing Javascript and Generating Source Maps
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return #<Process::Status: pid 10516 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
099a7993b3e582fb9da71a673a932d24a26aa35981a7d36114bb9fa3afc58f79
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Here is the hook part of the web_only.yml
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
          - git clone https://github.com/discourse/discourse-akismet.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
  before_bundle_exec:
    - file:
        path: $home/config/multisite.yml
        contents: |
         secondsite:
           adapter: postgresql
           username: discourse
           database: rs_discourse
           pool: 25
           timeout: 5000
           db_id: 2
           host_names:
             - test.test.com
  after_bundle_exec:
    - exec: cd /var/www/discourse && sudo -E -u discourse bundle exec rake multisite:migrate
## Remember, this is YAML syntax - you can only have one block with a name
run:
  ## If you want to configure password login for root, uncomment and change:
  ## Use only one of the following lines:
  #- exec: /usr/sbin/usermod -p 'PASSWORD_HASH' root
  #- exec: /usr/sbin/usermod -p "$(mkpasswd -m sha-256 'RAW_PASSWORD')" root
  ## If you want to authorized additional users, uncomment and change:
  #- exec: ssh-import-id username
  #- exec: ssh-import-id anotherusername
  - exec: awk -F\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print "Authorized SSH keys for this container:"; } NF>=2 {print $NF;}'
What did I miss?
Thank you very much
Ok, I’ve to had some fields:
before_bundle_exec:
    - file:
        contents: |
         secondsite:
           adapter: postgresql
           username: discourse
           password: SECRET
           host: data
           pool: 25
           timeout: 5000
           db_id: 2
           host_names:
             - test.test.com
