fuerst
(Bernhard Fürst)
December 14, 2016, 2:41pm
1
Doing a ./launcher rebuild discourse-web.yml I got this error:
Compiling css for kulturladen
rake aborted!
ActiveRecord::StatementInvalid: PG::UndefinedColumn: ERROR: column "uploaded_background_id" does not exist
LINE 1: ...categories"."updated_at" FROM "categories" WHERE (uploaded_b...
: SELECT "categories"."updated_at" FROM "categories" WHERE (uploaded_background_id IS NOT NULL) ORDER BY updated_at desc LIMIT 1
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/patches/db/pg.rb:90:in `exec'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/patches/db/pg.rb:90:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/connection_adapters/postgresql_adapter.rb:592:in `block in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/connection_adapters/abstract_adapter.rb:484:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/connection_adapters/abstract_adapter.rb:478:in `log'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/connection_adapters/postgresql_adapter.rb:592:in `exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/connection_adapters/postgresql_adapter.rb:584:in `execute_and_clear'
/var/www/discourse/lib/freedom_patches/fast_pluck.rb:41:in `select_raw'
/var/www/discourse/lib/freedom_patches/fast_pluck.rb:79:in `pluck'
/var/www/discourse/app/models/category.rb:108:in `last_updated_at'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/relation/delegation.rb:70:in `block in last_updated_at'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/relation.rb:302:in `scoping'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/relation/delegation.rb:70:in `last_updated_at'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:163:in `digest'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:153:in `stylesheet_filename'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:129:in `stylesheet_fullpath'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:80:in `compile'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:39:in `block in compile'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:36:in `synchronize'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:36:in `compile'
/var/www/discourse/lib/tasks/assets.rake:51:in `block (3 levels) in <top (required)>'
/var/www/discourse/lib/tasks/assets.rake:50:in `each'
/var/www/discourse/lib/tasks/assets.rake:50:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rails_multisite-1.0.6/lib/rails_multisite/connection_management.rb:126:in `block in each_connection'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rails_multisite-1.0.6/lib/rails_multisite/connection_management.rb:124:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rails_multisite-1.0.6/lib/rails_multisite/connection_management.rb:124:in `each_connection'
/var/www/discourse/lib/tasks/assets.rake:44:in `block in <top (required)>'
/var/www/discourse/lib/tasks/assets.rake:130:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-11.2.2/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:22:in `load'
/usr/local/bin/bundle:22:in `<main>'
I’m at the version: tests-passed and using a multi site installation with separate web and data containers.
Looks like the database column `` got added 2 days ago:
class AddUploadsToCategories < ActiveRecord::Migration
def up
add_column :categories, :uploaded_logo_id, :integer, index: true
add_column :categories, :uploaded_background_id, :integer, index: true
transaction do
Category.find_each do |category|
logo_upload = Upload.find_by(url: category.logo_url)
background_upload = Upload.find_by(url: category.background_url)
category.update_columns(
uploaded_logo_id: logo_upload&.id,
uploaded_background_id: background_upload&.id
Is there any way to upgrade the database scheme manually so I get my sites up again?
tgxworld
(Alan Tan)
December 14, 2016, 3:23pm
Did you run the migrations on your data container before rebuilding the web container?
fuerst
(Bernhard Fürst)
December 14, 2016, 3:25pm
3
No because I thought that is taken care of in the web containers YAML file by this hook:
after_bundle_exec:
- exec: cd /var/www/discourse && sudo -E -u discourse bundle exec rake multisite:migrate
If not: how am I supposed to migrate the data container?
tgxworld
(Alan Tan)
December 14, 2016, 3:30pm
4
Does rebuilding again fail as well?
Otherwise, we’re need to check if the migrations ran by running the following query in Postgres
SELECT * FROM schema_migration_details WHERE name = 'AddUploadsToCategories';
fuerst
(Bernhard Fürst)
December 14, 2016, 3:36pm
5
Rebuilding again fails as well. Did it 4 times.
The SELECT statement yields 0 records:
discourse_kulturladen=# SELECT * FROM schema_migration_details WHERE name = 'AddUploadsToCategories';
id | version | name | hostname | git_version | rails_version | duration | direction | created_at
(0 rows)
fuerst
(Bernhard Fürst)
December 14, 2016, 3:38pm
6
BTW: At the default multi site the migration did run:
discourse=# SELECT * FROM schema_migration_details WHERE name = 'AddUploadsToCategories';
695 | 20161202034856 | AddUploadsToCategories | d1bcdd8eb4d7+| 20f9aad539bc4929f9149ddf989fc8abb69329d3 | 4.2.7.1 | 129 | up | 2016-12-14 14:10:12.342404
(1 row)
tgxworld
(Alan Tan)
December 14, 2016, 4:10pm
7
Try running multisite:migrate manually.
fuerst
(Bernhard Fürst)
December 14, 2016, 4:30pm
8
I tried from within the data container. It’s code stays at 9th of Dec though (02b21a26ddfe48536251276c235c6c9ac9a7227a).
I probably need to run it from the web container which I can not access because the rebuild failed.
tgxworld
(Alan Tan)
December 15, 2016, 2:30am
9
Hmm ok I think I see where the problem is.
You’re only running multisite:migrate after the bundle exec hook but during the hook, assets are already being precompiled when the multisite DB hasn’t been migrated yet. To work around the problem, can you change your template to something like
before_bundle_exec:
- exec: su discourse -c 'bundle install --deployment --verbose --without test --without development'
fuerst
(Bernhard Fürst)
December 15, 2016, 9:14am
10
You are right - precompiling assets started before database migration. Adding your code above to the before_bundle_exec hook worked. Thanks a lot for your help!
I had to modify it slightly to get it executed properly. My hook for multi site looks like this now:
before_bundle_exec:
- file:
path: $home/config/multisite.yml
contents: |
# (your multisite.yml config here)
- exec: cd /var/www/discourse && sudo -E -u discourse bundle install --deployment --verbose --without test --without development
Should I consider this as a one time workaround or can this two exec stay forever in my template file?
Sander78
(Sander Datema)
January 10, 2017, 3:28pm
11
I’m glad I found this topic. Had the same problem. But even now I have an error:
INFO -- : Running `bundle install --deployment --verbose --without "development"` with bundler 1.13.7
The --deployment flag requires a Gemfile.lock. Please make sure you have checked
your Gemfile.lock into version control before deploying.
So it seems it’s missing that Gemfile.lock file.
In the end I fixed it by running the older version of Discourse I had, then:
enter it with launcher enter app
cd db/migrations
paste the contents of the migration file above into a new file
Now you can upgrade as usual with launcher rebuild app.
