I was attempting to do the stable branch update so rebuilding the container and it failed to work when pre-compiling the assets. So I looked around and similar issues happen when people have plugins installed so I double checked and we have none other than the defaults.
Then I went into the container and manually run the command with --trace and this is what I got back.
rake aborted!
ActiveRecord::StatementInvalid: PG::UndefinedTable: ERROR: relation "stylesheet_cache" does not exist
LINE 1: SELECT 1 AS one FROM "stylesheet_cache" WHERE "stylesheet_...
: SELECT 1 AS one FROM "stylesheet_cache" WHERE "stylesheet_cache"."target" = 'desktop' AND "stylesheet_cache"."digest" = '8817ec6e89b25fc3a01911bcd0000a3515671e5d' LIMIT 1
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.3/lib/patches/db/pg.rb:90:in `exec'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.3/lib/patches/db/pg.rb:90:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/postgresql_adapter.rb:822:in `block in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract_adapter.rb:378:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract_adapter.rb:372:in `log'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/postgresql_adapter.rb:822:in `exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/postgresql/database_statements.rb:137:in `exec_query'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/postgresql_adapter.rb:954:in `select'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:24:in `select_all'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/query_cache.rb:70:in `select_all'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:30:in `select_one'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:35:in `select_value'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/relation/finder_methods.rb:298:in `exists?'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:83:in `compile'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:39:in `block in compile'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:36:in `synchronize'
/var/www/discourse/lib/sass/discourse_stylesheets.rb:36:in `compile'
/var/www/discourse/lib/tasks/assets.rake:82:in `block (3 levels) in <top (required)>'
/var/www/discourse/lib/tasks/assets.rake:81:in `each'
/var/www/discourse/lib/tasks/assets.rake:81:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/gems/rails_multisite/lib/rails_multisite/connection_management.rb:86:in `block in each_connection'
/var/www/discourse/vendor/gems/rails_multisite/lib/rails_multisite/connection_management.rb:84:in `each'
/var/www/discourse/vendor/gems/rails_multisite/lib/rails_multisite/connection_management.rb:84:in `each_connection'
/var/www/discourse/lib/tasks/assets.rake:76:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:240:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:240:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:235:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:235:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:179:in `block in invoke_with_call_chain'
/usr/local/lib/ruby/2.0.0/monitor.rb:211:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:172:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:165:in `invoke'
/var/www/discourse/lib/tasks/assets.rake:136:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:150:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:106:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:106:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:106:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:115:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:100:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:78:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:176:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:75:in `run'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/bin/rake:33:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/rake:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/rake:23:in `<main>'
Tasks: TOP => assets:precompile:css
Migrations run and everything so not sure why something would just not exist? We were previously on tests-passed but not updating, waiting for the next stable release to go stable.
This is also a multi site setup and our container.yml file could be out of date I guess.
I manually did things in the container and everything appears to be working but obviously I want a proper rebuild done.
/cc @rodrigofarcas
