ShanniiWrites is experiencing significant lag on their Discourse forum hosted on DigitalOcean, even with only 250 total users and up to 30 online at once. The issue occurs during active discussions, with users needing to refresh to see updates and occasionally being logged out. They initially used a standard install but did not run discourse-setup after upgrading to a 3GB droplet. pfaffman and Stephen clarify that the official installation method is required for support, and the one-click install used by ShanniiWrites is unsupported. Stephen advises backing up the current setup, creating a new droplet, and following the documented install process. iAmMuu also asks about storage, noting 7.7GB of free space and 14.5GB used by backups, which may affect performance. Stephen suggests the current setup is not optimal and recommends a clean reinstall using the official guide.
I’ve created my Discourse forum on DigitalOcean and I currently have the 3GB droplet, which I thought would be enough to run my forum well. But at the moment, it’s really lagging.
Every time there are more that 10 people actively contributing to the same post at one time, it starts to lag significantly. They aren’t all necessarily posting at the same time. They take it in turns with no more than 3-4 people typing at the same time, but it causes issues.
They have to keep refreshing the page to see new posts, like posts or see who’s liked a post. They sometimes get a message saying they were logged out. It’s really affecting my traffic!
There are only 250 people on my forums in total and we get no more than 30 people online at the same time right now. But if things are bad with this number of people, I’m worried about potential new users and the general experience of being on my forum.
I don’t know, this keeps on popping rather frequently, people assume that Digitalocean’s one click app is an ‘official’ method of installing Discourse.
I ran discourse-setup and it seems people are still having lagging issues. There are 7 people on a post and it’s causing the new posts to not update immediately
thank you for your reply we will try to reach out to them.
But based on the specifications of the VM should it be able to support the described number of users (usually there are 11 active users at one time but it has been seen to increase to 20-30).
Also should we delete a few old discourse backups - there is only 7.7GB storage left, (14.5GB taken by backups), perhaps this is also contributing to the performance degradation?
The only recommendation I can make is that you back up your current install, spin up a new droplet, follow the documented supportable install and then restore your data.
