My plugin codes runs just once!(My own script shouldn't be cached)
AI 生成的摘要
The discussion revolves around a plugin that runs only once on the first page of a website. Alavi1412 initially shares a simple script that triggers an alert, but it only works on the first page. cpradio explains that the script likely only runs on page load, which happens once, and suggests subscribing to a different event, such as onPageChange.
Alavi1412 provides more code, which cpradio diagnoses as using $(document).ready, which only fires once. cpradio offers a solution using the onPageChange event and provides an example. Alavi1412 and broz both implement this solution, but broz encounters issues with the code not loading.
cpradio and Mittineague provide further guidance, suggesting that broz needs to move the majority of the code into a separate JS file and register it in the plugin.rb file. cpradio also recommends changing the function definition and removing unnecessary code.
Mittineague points out that broz needs to correct the file path in the register_asset method and considers using more descriptive naming in the code. cpradio encourages broz to make the JavaScript a function that can be called within the onPageChange invocation, similar to what the poll plugin does.
Hi.
I wrote a plugin and I run my code. my code run just for the first page of my website.even if it is a simple alert.for example if you open front page and go to categories page the alert doesn’t work on new page.
It isn’t cached, What you are seeing is your script likely only runs on page load, and page load only happens once. The page gets repainted and you likely need to subscribe to a different event.
Can you paste your script here? Or a link to it on GitHub (if it is located there)?
It can be anything like:
export default {
  initialize() {
    alert("hello");
this work just on first Page
this is my whole code:
export default {
  initialize() {
    $(document).ready(function() {
        var elements = document.querySelectorAll(".topic-list .main-link a.title");
        var elements2 = document.querySelectorAll(".badge-wrapper.box span.badge-category");
        var i = 0;
        var a1 = -1, a2 = -1, a3 = -1;
        for(i = 0 ;i < elements2.length ; i++)   //Finding the position of wanted topics
            if (elements2[i].innerHTML == "ورزشی")
            {               if(a1 == -1)
            a1 = i;
            else if (a2 == -1)
            a2 = i;
            else if(a3 == -1)
            a3 = i;
            document.getElementById('dyn1').innerHTML = elements[a1].innerHTML;
            document.getElementById('dyn1').href = elements[a1].href;
            document.getElementById('dyn2').innerHTML = elements[a2].innerHTML;
            document.getElementById('dyn2').href = elements[a2].href;
            document.getElementById('dyn3').innerHTML = elements[a3].innerHTML;
            document.getElementById('dyn3').href = elements[a3].href;
Yeah, $(document).ready will only fire once, as page repaints will not reload the DOM. You need to subscribe to a different event.
The API seems to offer a onPageChange event.
You would invoke it like so
import { withPluginApi } from 'discourse/lib/plugin-api';
function initializePlugin(api)
  api.onPageChange((url, title) => {
        // your code here
        console.log('the page changed to: ' + url + ' and title ' + title);
export default {
  initialize: function(container)
    withPluginApi('0.1', api => initializePlugin(api));
thank you very much. It helps me and was so useful
Thank you.Can you explain this code?
I don’t understand exactly what this is?
In short, it is importing the plugin-api library and then using that API’s onPageChange event to execute code of your choosing.
So when the user navigates to a “different page”, it will invoke anything in the //your code here area.
Hi,
Based on your example is this the correct syntax?
  initialize() {
    alert('alert boxes are annoying!');
export default {
https://github.com/BRoz/discourseoptin/blob/master/assets/javascripts/discourse/initializers/alert.js.es6
You don’t need this
  initialize() {
That would simply be
Making the full script
        // your code here
export default {
Hi, i’ve tried in every way but still the code isn’t loaded.
I let you check the plugin:
Do i miss something? Should i change the file name or the file extension to make the last part work?Because the first one work as it should.
Thank you very much for the help you gave me last time :heartbeat:
You put the code in the wrong file. That file is for whiteListing tags only.
You need to put the following
in https://github.com/BRoz/discourseoptin/blob/master/assets/javascripts/discourse/initializers/alert.js.es6
I would also rename alert.js.es6 to be discourse-opt-in.js.es6 so it more closely matches your plugin name.
I’ve tried this way, and i did that also now, you can try the plugin, and as you will see the code isn’t loaded.
Maybe you can try to achieve this result with a simple alert, but actually i’ve tried it and still don’t work.
:sweat:
I hadn’t looked at the actual code you had in there, but now after looking at it, it seems you may want to place the majority of this code in a separate JS file and in your plugin.rb you would do a register_asset "path to js file", :server_side
You can see something similar at
Then you would call your external javascript function in the plugin api onPageChange.
Right now, you have a lot of code in there that likely doesn’t belong. It isn’t meant to be housing functions, but more for calling them.
How to do that?
I created the js file
https://github.com/BRoz/discourseoptin/blob/master/assets/javascripts/discourse/initializers/discourse-opt-in.js
And included it in the plugin.rb
Thanks
I’m pretty well guessing at this point, but I think you have to change ! function to be var myFunction = function
Then remove (document, "script", "omapi-script")
And in your plugin api, do something like
myFunction(document, "script", "omapi-script");
I’m not even sure this is fully correct, but your javascript doesn’t like to be embeded in such an API, and it seems you haven’t a clue as to what it is doing… so we’re sort of at an impasse here because unless you know what it is doing, it is hard to tell you how to change it so it can be executed.
Note that “register_asset” starts from the asset folder.
so it should be more like
register_asset "javascripts/discourse/....
instead of
register_asset "assets/javascripts/discourse/....
Also, AFAIK if you name the files with the extension “.js.es6” it lets magic happen and you don’t need to register them.
Using more descriptive naming would be a help. Names like “r”, “t”, “e” and “s” don’t make it any easier to read the code.
@broz
If you can figure out how to make your javascript a function and not execute it immediately, then you can simply put that function statement at the bottom of your initializer and call it from within the onPageChange invocation.
Similar to what the poll plugin is doing here
