Mijn postgres start niet met mijn docker container
Caused by:
PG::ConnectionBad: connection to server on socket “/var/run/postgresql/.s.PGSQL.5432” failed: No such file or directory
Is the server running locally and accepting connections on that socket?
If you’re not following the standard install instructions then you’re mostly on your own, but I see a database.yml in one of your tabs, suggesting that the database is in a separate container, so you’ll want to crank that up first.
This is a development install right? Moving it to Development.
Have you started the postgresql service on your OS?
Now I am getting this error…I don’t get it because it was working fine and now something wrong :persevering_face:
/usr/local/lib/ruby/gems/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/postgresql_adapter.rb:83:in `rescue in new_client’: connection to server at “127.0.0.1”, port 5432 failed: Connection refused (ActiveRecord::ConnectionNotEstablished)
Is the server running on that host and accepting TCP/IP connections?
This is just my local install using docker, and it was working before :thinking: I guess I could try the standard install next.
No. If it’s development, you don’t want a standard install. I’m not sure what your issue is, though.
