Mysterious entries in topic_users table
A user fefrei reported finding mysterious entries in the topic_users table when running a Data Explorer query. The entries had a user ID that matched the topic ID, but the user ID did not exist in the users table.
After investigation by Mittineague and fefrei, it was determined that the issue was not related to the SQL query, but rather a bug in the Discourse code.
Mittineague discovered that the bug was related to the track_visit! method in app/models/topic_user.rb, which was incorrectly assigning the topic ID to the user ID when the user was not a valid User object.
Zogstrip pushed a fix for the bug, and gerhard suggested that a migration should be created to remove the invalid records from the table.
Mittineague and zogstrip discussed possible ways to remove the invalid records, and zogstrip pushed a commit with a safe deletion query.
Codinghorror awarded gold stars to Mittineague and fefrei for their work in tracking down the bug.
I’m running a Data Explorer query to see which users read a specific post:
-- [params]
-- integer :topic = 0
SELECT *, total_msecs_viewed / (1000 * 60) as mins_read
FROM topic_users
WHERE topic_id = :topic
ORDER BY total_msecs_viewed DESC
The results look plausible, except for a mysterious nonexisting user:
This is the result for topic 200. The user id 200 is not used in my installation (I have fewer users).
The same thing is happening for all other topics, there is always an entry for a “user” whose id matches the topic id.
Am I overlooking a very obvious bug in my SQL code? Is this entry really there? Should it be?
1 „Gefällt mir“
If you run
SELECT *
FROM users
WHERE id = 200
you might be able to spot the problem.
My guess would be a NULL name field
This returns 0 results, as expected.
So you know it’s a deleted account?
In that case you might want a more complex query that takes that into it.
1 „Gefällt mir“
No, the account never existed – I only have about 150 users, so the id has never been used.
Hmmm, is that the MathJax topic id?
SELECT *
FROM topics
WHERE id = 200
Yes, it is. As I said above, this happens in multiple (or all?) topics. Topic 201 has a mysterious user 201, and so on.
1 „Gefällt mir“
So you did.
I was getting some “invalid int” errors until I changed “:topic” to “:topicid” so I at first thought it might involve how “params” works.
But even after removing that and hard-coding in the ids, I still got the mysterious result.
I notice it doesn’t seem to happen when the id is 55 or below, but always for ids 56 or greater.
55 seems like an odd value for a switch to be happening.
Are your results consistent with <=55 OK, >=56 Not ?
EDIT
Hmmm, 55 is my highest users id + 2
(yes, I have that many test accounts on my localhost site)
1 „Gefällt mir“
With the possibility of deleting users, 55 could plausibly be the highest user id.
Are you sure this isn’t happening for lower user IDs? The entries would look quite normal…
I tried to look at all entries where the user id equals the topic id:
SELECT *
FROM topic_users
WHERE user_id != topic_id
ORDER BY user_id
Even for low ids, the results look strange: Almost all have highest_seen_post_number = NULL, for example. In other rows in this table, this column almost always contains a plausible date.
I’m starting to believe that this is a #bug: It looks like something is inserting rows here and mistakes the topic id for the user id?
4 „Gefällt mir“
I’ve been looking at topic_users a bit lately.
I was confused as to why there would be these two fields
last_read_post_number    integer    null
highest_seen_post_number    integer    null
I mean, if I read it, I saw it, no?
Then I found this in app/models/topic_user.rb
      # In case anyone seens "highest_seen_post_number" and gets confused, like I do.
      # highest_seen_post_number represents the highest_post_number of the topic when
      # the user visited it. It may be out of alignment with last_read, meaning
      # ... user visited the topic but did not read the posts
In other words, if a topic has 100 posts, but I only read the first 50, the two will not be the same.
I just ran
SELECT *
FROM topic_users
WHERE last_read_post_number IS NULL
OR  highest_seen_post_number IS NULL
In all results both read and seen were NULL
and I noticed in all results total_msecs_viewed was zero.
In some, it was not the topic id that was used, but the post id
My guess, without having looked more closely into the code yet, is that there is a “divide by 0” error happening somewhere.
3 „Gefällt mir“
That’s some additional weirdness – thanks for the research!
But even a division through zero doesn’t really explain the nonexistent
user ids… :frowning:
I’m not sure if it’s more to do with Discourse or Data Explorer or both.
I’ll try running some queries in the postgres console tomorrow (I need to eat and get some sleep) to see if the results are similar.
1 „Gefällt mir“
An update after an interesting morning.
I was wrong about two things
This was wrong, I was misled by a seemingly unrelated weirdness. (that sent me off on a tangent for a good while)
What I had assumed to be post ids are in fact topic ids.
For whatever unknown reason both my topics and posts tables “skipped” ids.
In the topics table ids are serial from 1 - 166, then skipped to 1796, 1797, then skipped to 1830 and have been sequential serial values since.
Likewise the posts table ids are 1 - 188, skip to 2708, skip to 2747 then sequential since
I don’t know what happened, but I was exploring the differences between
“Global Notice” vs. “Banner Topic” vs. “Global Pinned Topic” vs. “Pinned Topic” so maybe that has something to do with it.
Topics
166	Pinned Stats query          		^^^^^
                        2016-05-04 07:12
1796	Banner Poll results
                        2016-05-06 01:40
1797	Limit Banner Use?
                        2016-05-06 07:15
1830	Topic for moved PM testing		vvvvvvvv
                        2016-05-06 20:48
Posts
888	Pinned Stats query (3)      		    ^^^^^
                        2016-05-04 08:42
2708	Banner testing - take two (13)      7d unbannered may 6 unpinned
                        2016-05-05 06:34
2747	Going off the grid for a while (35)	vvvvvvvv
                        2016-05-05 09:19
* created at datetimes
Anyway, I was also wrong about
Topic ids were actually being used as user ids, but because there were actual users with those id values it didn’t look obviously wrong at first.
The incorrect user ids are in the Postgres table and not a result of how Data Explorer works with the data
 user_id | topic_id | posted | last_read_post_number | highest_seen_post_number |
      56 |       56 | f      |                       |                          |
 last_visited_at       |      first_visited_at      | notification_level |
 2016-05-12 17:47:06.711945 | 2016-03-14 19:18:55.588447 |                  1 |
 notifications_changed_at | notifications_reason_id | total_msecs_viewed |
      |                         |                  0 |
 cleared_pinned_at | id  | last_emailed_post_number | liked | bookmarked
      | 434 |                          | f     | f
I don’t know how or why the topic ids could be getting used as user ids, but my feeling is it has to do with “no owner” posts. eg.
system = user id -1
“small actions”
anonymized accounts
I was alarmed when I saw that a March “post closed Flagged” message to FluffGuy1 with topic id 52
had RoyalGuy1 user id 52 as a topic_user.
But luckily RoyalGuy1 has no indication of it’s existence displayed anywhere, he is not included as a user in the message, and going to the URL gives “no permission”.
5 „Gefällt mir“
Awesome work, thanks!
So this definitely looks like a bug, I’ll move the topic.
1 „Gefällt mir“
Yes, I think it’s a bug somewhere.
I’ve found a differentiation area
SELECT COUNT(dtid)
FROM (SELECT DISTINCT id FROM topics) AS dtid
count = 182
SELECT COUNT(dtuid)
FROM (SELECT DISTINCT topic_id FROM topic_users) AS dtuid
count = 182
SELECT COUNT(dtuntid)
FROM (SELECT DISTINCT topic_id FROM topic_users WHERE last_read_post_number IS NULL) AS dtuntid
count = 170
SELECT COUNT(dtuptid)
FROM (SELECT DISTINCT topic_id FROM topic_users WHERE user_id = topic_id) AS dtuptid
count = 170
The difference between the 182 / 170 / 12 ?
My install came with 12 “seeded” topics
id	title				 user
1	About the Lounge category	 system
2	About the Meta category		 system
3	About the Staff category	 system
4	Terms of Service		 system
5	FAQ/Guidelines			 system
6	Privacy Policy			 system
7	Assets for the site design	 system
8	Welcome to Discourse		 system
9	Welcome to the Lounge		 system
10	READ ME FIRST: Admin Quick Start Guide	 system
11	This is a test topic		 eviltrout
12	Welcome to Discourse!	 	 system
1 „Gefällt mir“
I had AdminGuy1 create a new topic in the meta category
I then went directly to the Data Explorer and ran
SELECT * FROM topic_users ORDER BY topic_id DESC LIMIT 10
members that were Watching / Tracking the meta category were there, and the last id had a user_id = topic_id
I then had Mittineague create a new category - Temporary
I did not visit the new category’s generated About page
Going to Data Explorer and running the same query gave the same results
i.e. no new rows had been added to the topic_users table
I then viewed - aka visited - the new category’s About page but did not edit it.
Going to Data Explorer and running the same query showed that 2 rows had been added to the topic_users table.
The first was Mittineague.
The last was another user_id = topic_id
This suggested the “when”. and after poring through lines of code I think I may have found the “where”.
app/models/topic_user.rb lines 128 - 139 are
    def track_visit!(topic,user)
      topic_id = topic.is_a?(Topic) ? topic.id : topic
      user_id = user.is_a?(User) ? user.id : topic
      now = DateTime.now
      rows = TopicUser.where(topic_id: topic_id, user_id: user_id).update_all(last_visited_at: now)
      if rows == 0
        TopicUser.create(topic_id: topic_id, user_id: user_id, last_visited_at: now, first_visited_at: now)
      else
        observe_after_save_callbacks_for topic_id, user_id
I am far from being a Ruby expert, and I do not know all the inter-relationships in Discourse, but in particular line # 130 looks like the probable culprit. i.e.
That is, if I’m reading the code correctly, the line translates roughly to
if user is a User assign user.id to user_id else assign topic to user_id
If this is the problem, I don’t know what the best way to deal with it would be.
4 „Gefällt mir“
Preeeetty sure it should be user instead of topic here.
Awesome detective work :mag:
2 „Gefällt mir“
Just pushed a fix. Not sure how it got there in the first place :frowning:
https://github.com/discourse/discourse/commit/6137bb46d31f0bb3ef3a4488c68a17a750ddb84e
7 „Gefällt mir“
Should there be a migration that removes the invalid records from the table?
3 „Gefällt mir“
I was thinking of that too
First thought would be
WHERE topic_id = user_id
except there may be cases where an actual member with the same id as a topic should be there
Adding notification_level = 1 (assigned as the default) and
would only falsely delete members that had set the category as Normal via the category drop-down which seems like that would be very rare, but is possible I guess.
The safest would be
topic_id > MAX(users.id)
but depending on how many members there are could leave quite a few.
2 „Gefällt mir“
