ブラックリスト入りしたユーザーエージェントの名前
If in the Web Crawler User Agents tab
I have the name of the bot, that’s exactly what I have to enter in the options to make sure that the bot is blocked or another name ?
for example
MBCrawler/1.0 (https://monitorbacklinks.com/robot)
then what should be input here
MBCrawler/1.0 or a whole line or maybe any word containing the name of that bot ?
2Q
And by the way, are you blocking these bots or not because I read different opinions? Maybe there’s no point in worrying about any bot.
But if so, why is Ahrefs blocked by default, etc . What is the purpose of this?
「いいね!」 1
I think monitorbacklinks would be best as it is the longest unique string.
「いいね!」 2
Hello Sylwia, and thank you for adding this post.
  1. Do you know what the SEO implications of blocking bots from google may be?
  2. Did you get a response to your second question:
I am in the process of blocking bots to keep my pageviews under control and within by subscription plan.
「いいね!」 1
