Limitación de agentes de usuario y formato de configuración
In the slow down crawler user agents setting, is the value case insensitive as per the blacklisted crawler user agents.
eg is YandexBot a valid setting or does it need to be the complete thing - Mozilla/5.0 (compatible; YandexBot/3.0; +http://yandex.com/bots).
The answer should be no, but I’m not sure what we actually did here. @sam worked on this I think.
This is a directive that is added to robots.txt with the same casing that you enter in the setting per: FEATURE: allow for setting crawl delay per user agent · discourse/discourse@3a7b696 · GitHub
So, depending on how the particular bot interprets robots.txt it will be case sensitive or insensitive.
Yandex documentation seems to imply you would use the string Yandex there.
3 Me gusta
Cool, thanks for that :slight_smile:
2 Me gusta
