The ending comma with no following selectors could very well be causing trouble.
I just looked a bit for an online scss linter but but all I saw were dev side. Short of using a linter, that leaves manually pairing up curly braces - ugh!
In this stylesheet in particular the commas are at the end of many lines because it’s a work in progress and I add elements piece by piece. BTW the commas do not produce any errors infact I see the changes when I click Save.
Comments in my stylesheet now are both // or /* */ . I see that some online SCSS validators dislike //. But not Discourse.
As I said it’s a work in progress, I really don’t like use // but I wanna try the new panel with SCSS and for now there’s no problem in the preview.
When I finish the work (it’s mostly a rework where I’m cleaning the old stylesheets that I wrote over the years) I want to use only /* */ for comments.
It doesn’t seem like colors don’t seem to update when a theme updates a color scheme.
I updated a color scheme in my theme repository. It updates the color scheme in the admin ‘colors’ page correctly, but does not update the resulting css.
Correct theme selected:
Selected colors correctly changed on theme update:
Resulting icons should be blue, nothing in the theme overrides. I have a separate color scheme with the exact same colors that works with this:
Edit:
A rebuild fixed the colors, but this seems strange as to why I’d need to rebuild the entire site just to apply the correct color theme.
Hi Jeff,
I can not reproduce this issue at all, can anyone else? What are the exact steps?
I can’t reproduce it now, but when I was creating the material design theme I experienced similar issues. I didn’t have to do a rebuild, but I did have to re-save the CSS after changing the colors for the variables to reinitialize. As I said, can no longer reproduce that behavior so that might have already been addressed.
I think these are the full steps I did - I’ll try and reproduce today to confirm.
Create a theme repository with no color theme attached.
Import the theme into a discourse instance.
Apply the theme as default, attach an existing color theme.
Push an update to the theme to have a color scheme.
Pull the changes and switch to using the new (theme owned) color theme.
Push an update to the theme’s colors (no CSS changes)
Pull changes into discourse. Noticed that no colors change.
I didn’t try to edit the CSS in the theme, since I figured it would do it on the theme pull.
I can recreate this behavior on my local dev environment, but not on the Digital Ocean docker instance. On local, as soon as I make a change to the CSS and save it, it refreshes with the correct colors. If it happens on my docker instance I will let you know.
EDIT: I have recreated in production as well, but the same as above, as soon as I re-save the CSS file, the colors return to normal.
Ahh so this is specifically for an updated color scheme from a remote repo? I will add a test for it.
I am not using a color scheme from a remote repo. These are my steps to reproduce:
.d-header{
background-color: $header-background;
Observed Result: The background color of the header doesn’t change unless you go back in to your theme and re-save the CSS
Yeah… that makes sense, I forgot to invalidate theme on color var changes, I only invalidate the app.css, will fix.
Fixed per:
Thanks for the quick fixes Sam, I can confirm on my side that the colors change immediately – looks great!
Edit: Not sure if this is a bug here, or in the materials design theme, but it does not seem to update for some components - various elements that use lighten() functions are not pulling from the newly specified color schemes for some reason? Here’s a screenshot when swapping the material design theme from the Material Dark color theme to the Blue/Red theme. The topic body doesn’t look like it’s updating its colors correctly –
(sorry for the cruddy screenshot; ubuntu wants to not play nicely with screenshot tools right now)
specifically this element:
is being computed as:
.category-list, .topic-list:not(.categories) {
background-color: #3b3b3b;
(Where secondary is fafafa for the chosen color theme.)
If it helps, this is not the default theme, but a user selectable one. The default theme’s secondary is 202020
Can you touch CSS is the theme (which should fix it) and then see if you can break it again?
Be sure to check out latest in “Theme Land” cause you can now ship custom fonts if you need to…
I can confirm that touching the CSS fixes this, but changing the color theme breaks it again back to #3b3b3b
(Running v1.8.0.beta11 +140 in case I didn’t grab the latest patch somehow.)
You are going to need to be on +147 I think. Try getting latest.
If a font is freely available via a CDN (like Google Fonts) is there any reason to ship them like this vs a link?
It will work behind firewall I guess, but same pattern works for any asset
Must have tried to rebuild+pull too soon – looks like this in good, working order post updates - thanks Sam!
Edit: Should a user selected theme be attached to a specific client/browser, or for the specific user login? I seem to have the ability to pick different themes across different browsers for a single user – is this the expected behavior?
Yes that is the expected behavior, user themes are “per device” and a different browser is a different “device”.
