Need help getting SSO to function correctly
I can not get the single sign on to work correctly and just wanted t run through my steps.
I am using:
Wordpress 4.5.3.
Theme Guru 2.3
Have Sensei LMS plug-in installed
Have buddypress installed.
Have jetpack installed
I went through and added the api key. Then I added auth-key in the box for SSO security key from w-config file .
I then logged out of wordpress, logged back in, opened up Discourse.
-I was not signed in.
-When I hit sign in I was not asked for my Wordpress credentials.
Are you using the wp-discourse plugin?
إعجابَين (2)
WP-Discourse version .70
I think I may have figured it out. I didn’t enable the sso setting son discourse. I will do so now and see if that helps.
3 إعجابات
Its working. Thanks for building this @simon
إعجاب واحد (1)
I didn’t build it, I just help maintain it :slight_smile:
