Need help! Rebuild app, no space left on device
סיכום מבוסס בינה מלאכותית
The discussion revolves around resolving an error in rebuilding an app due to no space left on the device. Nam_Nguyen encounters an error while adding a plugin to the app.yml file and rebuilding the app. The error logs reveal a “No space left on device” issue.
Nam_Nguyen is advised by mpalmer that the error message is quite clear in indicating the problem. fefrei provides helpful hints to reclaim space, including running /var/discourse/launcher cleanup, sudo apt-get autoremove, and sudo apt-get clean.
Nam_Nguyen successfully resolves the issue by running these commands: apt-get autoclean, apt-get autoremove, and ./launcher cleanup in the /var/discourse directory.
Hello, I try to add plugin to app.yml file , but when I run Rebuild app, I have Error in bellow, can anyone help me please, Thank you so much :slight_smile:
155:M 11 Nov 08:14:09.904 # Error trying to save the DB, can't exit.
155:M 11 Nov 08:14:09.904 # SIGTERM received but errors trying to shut down the server, check the logs for more information
2016-11-11 08:14:09 UTC [46-2] LOG:  database system is shut down
2016-11-11 08:14:09 UTC [50-1] LOG:  could not write temporary statistics file "pg_stat/db_16384.tmp": No space left on device
2016-11-11 08:14:09 UTC [50-2] LOG:  could not close temporary statistics file "pg_stat/db_1.tmp": No space left on device
2016-11-11 08:14:09 UTC [50-3] LOG:  could not close temporary statistics file "pg_stat/db_12413.tmp": No space left on device
2016-11-11 08:14:09 UTC [50-4] LOG:  could not close temporary statistics file "pg_stat/db_0.tmp": No space left on device
2016-11-11 08:14:09 UTC [50-5] LOG:  could not close temporary statistics file "pg_stat/global.tmp": No space left on device
I, [2016-11-11T08:14:19.868506 #13]  INFO -- : exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid:155 did not terminate cleanly, forcing termination!
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle install --deployment --verbose --without test --without development' failed with return #<Process::Status: pid 279 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
699943b3be202511b68df0e45a0c97641224fd6cf5fc53443960d47a3e447d3d
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
That seems like a pretty definitive error to me.
Some hints:
  • /var/discourse/launcher cleanup can reclaim space from older containers
  • sudo apt-get autoremove && sudo apt-get clean can reclaim space from older and cached packages
I try this, It’s oki now
apt-get autoclean
apt-get autoremove
cd /var/discourse
./launcher cleanup
Thank you!
