התאמה אישית חדשה של סרגל הצד של ה-admin! 😻
omg yes! thank you @awesomerobot and team! this is, well awesome! :star_struck: :clap:
i am so happy :grin: :partying_face:
15 לייקים
just a note - when i configured this section withe new pop up, it inserted it below the other custom links section i had for my users (with the globe icon), so i had to delete the previous custom links and set them up again to put it below the Community section.
edit: i have since discovered that reloading the browser after customizing the Community section fixes this and puts the sections in the proper order on the side-bar. :slight_smile:
this pretty much makes most of my side-bar mod theme component useless, which is a good thing :smile:
4 לייקים
question: would it be at all possible to make it so the pop-up configuration modal doesn’t close when one click/ taps outside the modal area?
lol you know i am hammering away at this thing to find bugs :sweat_smile:
4 לייקים
A small question: after this change, how can I modify the translation of the sidebar section?
It looks like My Posts is stuck in English
Update:
The localization works fine if I rename it to “my_posts”,
לייק 1
icons don’t actually seem to be changeable - locked into each heading. i would like arrows on the side of the configuration pop-up for moving links up and down to re-order.
does translated text-replacement work?
We use the click-outside to cancel pattern for all modals, so it’d be exceptional to do that in this case.
But I can see why you’re asking for something like this.
If you open the modal and tinker a bunch, it’s pretty easy to lose that work as is. Something to think about @awesomerobot / @kris.kotlarek :thinking:
2 לייקים
yea i noticed it does this for all modals. it’s pretty easy to tap outside a pop-up.
לייק 1
Apparently the team didn’t take names with spaces into account. Replacing spaces with _ makes translation work :joy:
2 לייקים
hah that is good to know. thanks!
i feel like there is some functional redundancy here with the Community section and global custom links sections.
:thinking:
לייק 1
Yep, there’s certainly significant overlap. I think you could consider this the “default” global section (that includes the ablity to restore the defaults).
לייק 1
