New: Tags removed from composer when creating shared draft bug
The discussion is about a bug where tags are removed from the composer when creating a shared draft. Ed_Bobkov reported the issue despite it being marked as fixed in another topic.
To reproduce the issue, Ed_Bobkov followed these steps:
  1. Created a topic
  2. Saved it as a draft in the Drafts category
  3. Set a category to publish in the future
  4. Added a tag
  5. Saved the topic.
The tag disappeared after saving.
jomaxro and jomaxro were unable to reproduce the issue using similar steps. Ed_Bobkov clarified the process, explaining that the category cannot be set initially and must be chosen after saving the draft in the Drafts category. The tags are then loaded from the destination category, but still disappear after saving.
I found this topic Tags removed from composer when creating shared draft
It’s said that this issue is fixed. @jomaxro, @eviltrout
But I have this problem.
My instance is 2.6.0.beta1 fd02856f80
So I created a Drafts category and set it as a Shared drafts category in admin settings.
Then I filled in the topic:
  1. created a topic, saved it,
  2. set a category to publish in the future
  3. set a tag
  4. saved the topic.
While saving the draft I saw that for 1 second that the tag was visible, but next second it dissapeared.
Any ideas what could prevent me from saving a tag within a draft topic?
Hey Ed,
I’m having a hard time reproducing this. The tag I added isn’t disappearing.
My steps:
  1. Click New Topic
  2. Change to Shared Draft via the composer action button
  3. Write a Title
  4. Set the category
  5. Write the body
  6. Click “create shared draft”
  7. Click the edit pencil next to the title
  8. Add a tag and save
The tag is still there for me. I also tried the edit via the full edit pencil below the post, still worked.
If I want to publish the post in a future, in a draft mode I can’t set a category at this step.
Firstly, I need to save it in the Drafts category not to publish the post immediately.
Then I edit the draft and choose the category in a special menu (not an ordinary in a composer).
When you chose the Destination category, you can edit the draft post and choose necessary tags that are loaded from the destination category. Choose smth, save it. Pay attention that while saving the chosen tags are visible and then dissapear.
Still no repro. Test steps are now:
  1. Click New Topic
  3. Write a Title
  4. Ignore (don’t set) the category
  5. Write the body
Tag still there after saving.
