I have the admin role for our account, and when I try to click on “New Webhook” the button is clickable, but nothing happens, and we don’t have anything in the console or network layer.
Is there some solution to that? Would it be a bug or a permission bug?
Hello, I think this issue has been fixed a few days ago. Webhook creation broken in latest build? I am pretty sure if you update your site to the latest it will fix it for you.
The version section is visible to admins, though only if you’re self-hosted. Do you have managed hosting? If so, you would need to ask your provider to update your instance.
I’ve slipped this topic over into #support as the bug has already been fixed and we just need to work out the best way to get your site updated to take advantage of it.
Can you tell us a little bit about how you installed your site, or who you host with?
