Next selection shortcut key J jumps from first post to bottom of page
AI 生成的摘要
A bug has been reported where using the keyboard shortcut J to navigate through a topic with suggested topics at the bottom causes it to jump from the first post to the suggested topics list, rather than moving to the next post. This issue occurs when the following steps are taken:
  1. Navigate to a long topic
  2. Scroll to the end to view suggested topics
  3. Use K to return to the first post
  4. Press K again
  5. Press J cpradio has provided these steps to reproduce the issue. However, sam believes that this bug may have been fixed by @dan in the past.
When I use the keyboard shortcuts K and J to move the selection in the topic below, the J key jumps from the first reply to the suggested topic list at the bottom of the page.
I used J to go to the end of the topic then to the end of the suggested topic list. I then used K to go back up to the top of the topic. Once I had done that J no longer moves from the first post to the next post, it now moves to the first suggested topic on the list at the end of the topic. If I close the topic window and return to it, I have to follow the same steps to reproduce the problem. It is consistent in the topic I’ve linked to using both Chrome and Firefox (both 64-bit versions).
I’m not sure why this rather esoteric problem occurs. It didn’t reproduce in a couple of other topics I looked at including another how to. I do wonder if it is something to do with more J keypresses than were needed to get to the start or end of the items.
2 个赞
Ahh, yup. For easier repo steps
  1. Navigate to Long Topic
  2. Scroll to end to see Suggested Topics
  3. Use k to go back to first post
  4. Once at first post, press k again
  5. Press j, you jump to suggested topics.
6 个赞
我相当确定 @dan 之前已经修复过这个问题了。
3 个赞
