Discourseインストールの強化のためのNftablesルール
皆さん、こんにちは。
初めての投稿です。私の経歴は、10年以上にわたりLinuxサーバーを管理してきました。約1週間前にDebian BullseyeサーバーにDiscourseをインストールしました。今のところ、非常に気に入っています!
さて、ホストシステム(例:Webサーバー)に通常のセキュリティ強化策を実装したいと考えています。これには、とりわけnftablesルールセットが含まれます。一般的にこれらを使用しています。
#!/usr/sbin/nft -f
# Purge/Flush      #
flush ruleset
# Incoming Traffic #
table inet filter {
   chain input {
      type filter hook input priority 0; policy drop;
      # Allow loopback interface
      iifname lo accept
      # Rate limit ICMPv4|ICMPv6 traffic
      ip protocol icmp icmp type { echo-request, echo-reply, destination-unreachable, time-exceeded, parameter-problem, router-solicitation, router-advertisement } limit rate over 5/second drop
      ip6 nexthdr icmpv6 icmpv6 type { destination-unreachable, packet-too-big, time-exceeded, echo-request, parameter-problem, echo-reply, nd-router-solicit, nd-router-advert, nd-neighbor-solicit, nd-neighbor-advert, ind-neighbor-solicit, ind-neighbor-advert } limit rate over 5/second drop
      # Allow packets to established/related connections
      ct state established,related accept
      # Drop invalid connections
      ct state invalid drop
      # Allow ICMPv4: Ping requests | Error messages | Router selection messages
      ip protocol icmp icmp type { echo-request, echo-reply, destination-unreachable, time-exceeded, parameter-problem, router-solicitation, router-advertisement } accept
      # Allow ICMPv6 traffic (https://tools.ietf.org/html/rfc4890#page-18)
      ip6 nexthdr icmpv6 icmpv6 type { destination-unreachable, packet-too-big, time-exceeded, echo-request, parameter-problem, echo-reply, nd-router-solicit, nd-router-advert, nd-neighbor-solicit, nd-neighbor-advert, ind-neighbor-solicit, ind-neighbor-advert } accept
      # Allow SSH access on port 2222 [rate limit]
      tcp dport 2222 ct state new limit rate 3/minute accept
      # Allow HTTP / HTTPS traffic
      tcp dport { http, https } accept
      # Reject other packets
      ip protocol tcp reject with tcp reset
      ip6 nexthdr tcp reject with tcp reset
# Forward Traffic  #
   chain forward {
      type filter hook forward priority 0; policy drop;
# Outgoing Traffic #
   chain output {
      type filter hook output priority 0; policy accept;
      oifname lo accept
しかし、有効化後、Discourseが動作しなくなりました。Dockerインストールにパッケージが渡されていないのではないかと疑っています。特にこのルールが問題になる可能性があります。
# Forward Traffic  #
   chain forward {
しかし、すぐにいじる前に、この問題に対処したことがある人がいて、ベースシステム用の動作するファイアウォールルールを持っているか尋ねたいと思いました。これらのルールは、Docker Discourseのインストールにとって意味があるのでしょうか?これまではDockerにはほとんど関心がありませんでした。
追加情報。これらのファイアウォールルールは、Docker(docker-ce)によって自動的に追加されます。
table ip nat {
	chain DOCKER {
		iifname "docker0" counter packets 0 bytes 0 return
		iifname != "docker0" meta l4proto tcp tcp dport 443 counter packets 155 bytes 7070 dnat to 172.17.0.2:443
		iifname != "docker0" meta l4proto tcp tcp dport 80 counter packets 128 bytes 6263 dnat to 172.17.0.2:80
	chain POSTROUTING {
		type nat hook postrouting priority srcnat; policy accept;
		oifname != "docker0" ip saddr 172.17.0.0/16 counter packets 34 bytes 2188 masquerade
		meta l4proto tcp ip saddr 172.17.0.2 ip daddr 172.17.0.2 tcp dport 443 counter packets 0 bytes 0 masquerade
		meta l4proto tcp ip saddr 172.17.0.2 ip daddr 172.17.0.2 tcp dport 80 counter packets 0 bytes 0 masquerade
	chain PREROUTING {
		type nat hook prerouting priority dstnat; policy accept;
		fib daddr type local counter packets 11439 bytes 550595 jump DOCKER
	chain OUTPUT {
		type nat hook output priority -100; policy accept;
		ip daddr != 127.0.0.0/8 fib daddr type local counter packets 0 bytes 0 jump DOCKER
table ip filter {
	chain DOCKER {
		iifname != "docker0" oifname "docker0" meta l4proto tcp ip daddr 172.17.0.2 tcp dport 443 counter packets 155 bytes 7070 accept
		iifname != "docker0" oifname "docker0" meta l4proto tcp ip daddr 172.17.0.2 tcp dport 80 counter packets 128 bytes 6263 accept
	chain DOCKER-ISOLATION-STAGE-1 {
		iifname "docker0" oifname != "docker0" counter packets 588 bytes 44199 jump DOCKER-ISOLATION-STAGE-2
		counter packets 1187 bytes 428425 return
	chain DOCKER-ISOLATION-STAGE-2 {
		oifname "docker0" counter packets 0 bytes 0 drop
		counter packets 588 bytes 44199 return
	chain FORWARD {
		type filter hook forward priority filter; policy drop;
		counter packets 1187 bytes 428425 jump DOCKER-USER
		counter packets 1187 bytes 428425 jump DOCKER-ISOLATION-STAGE-1
		oifname "docker0" ct state related,established counter packets 316 bytes 370893 accept
		oifname "docker0" counter packets 283 bytes 13333 jump DOCKER
		iifname "docker0" oifname != "docker0" counter packets 588 bytes 44199 accept
		iifname "docker0" oifname "docker0" counter packets 0 bytes 0 accept
	chain DOCKER-USER {
	chain INPUT {
		type filter hook input priority filter; policy accept;
よろしくお願いします。
@OrkoGrayskull さん、検索で見つかりましたか?
Docker がファイアウォールとどのように連携するかの背景がもう少し詳しく説明されています。
スレッドを読み、自分で何かをテストしました。Dockerは独自のiptablesルールを導入し、インストール時、またはdockerサービスが(再)起動/ロードされたときに適用します。
service docker restart
これらのルールセットがないと、Discourseのインストールは機能しません。つまり、コンテナをインストール、再構築、または再起動する際には、これらのルールが存在する必要があります。そうしないと、エラーメッセージが表示されます。
Error response from daemon: driver failed programming external connectivity on endpoint app (e4d4d3cc812a11862ee6aaa6ab453e61b95da1e6d90f9a76a71959148d228476):  (iptables failed: iptables --wait -t nat -A DOCKER -p tcp -d 0/0 --dport 443 -j DNAT --to-destination 172.17.0.2:443 ! -i docker0: iptables: No chain/target/match by name.
 (exit status 1))
しかし、Discourseのインストールが完了した後、またはアップデート後にコンテナが再起動された後は、Dockerのルールは必要なくなるようです。その場合、次のnftablesルールをロードできます。
#!/usr/sbin/nft -f
# Purge/Flush      #
flush ruleset
table inet filter {
   chain input {
      iifname lo accept
      # Allow SSH access on port 7777 [rate limit]
      tcp dport 7777 ct state new limit rate 3/minute accept
# Forward Traffic  #
   chain forward {
   chain output {
      oifname lo accept
これで別の質問になりますが、どうすればよいでしょうか?
承知しました。これで理解できたと思います。Discourse(Docker)で動作するntftablesルールセットです。
Debian(Bullseye)で最初のDiscourseインストール後に以下を実行してください。
[1] インストール後にDockerルールセットを保存します。
nft flush ruleset
systemctl restart docker
iptables-save > iptables-docker.conf
iptables-restore-translate -f iptables-docker.conf > docker.nft
[2] ルールセットを適用して表示します。
nft -f docker.nft
nft list ruleset
Discourseインストール後のエクスポートされたルールセットは次のとおりです。
table ip filter {
	chain INPUT {
	chain FORWARD {
		type filter hook forward priority filter; policy accept;
		counter jump DOCKER-USER
		counter jump DOCKER-ISOLATION-STAGE-1
		oifname "docker0" ct state established,related counter accept
		oifname "docker0" counter DOCKER
		iifname "docker0" oifname != "docker0" counter accept
		iifname "docker0" oifname "docker0" counter accept
	chain OUTPUT {
		type filter hook output priority filter; policy accept;
	chain DOCKER {
		iifname != "docker0" oifname "docker0" ip daddr 172.17.0.2 tcp dport 443 counter accept
		iifname != "docker0" oifname "docker0" ip daddr 172.17.0.2 tcp dport 80 counter accept
		iifname "docker0" oifname != "docker0" counter packets 0 bytes 0 jump DOCKER-ISOLATION-STAGE-2
		counter return
		oifname "docker0" drop
		counter return
	chain DOCKER-USER {
		counter return
table ip nat {
	chain PREROUTING {
		fib daddr type local counter jump DOCKER
	chain INPUT {
		type nat hook input priority 100; policy accept;
	chain OUTPUT {
		ip daddr != 127.0.0.0/8 fib daddr type local counter jump DOCKER
	chain POSTROUTING {
		oifname != "docker0" ip saddr 172.17.0.0/16 counter masquerade
		ip saddr 172.17.0.2 ip daddr 172.17.0.2 tcp dport 443 masquerade
		ip saddr 172.17.0.2 ip daddr 172.17.0.2 tcp dport 80 masquerade
	chain DOCKER {
		iifname "docker0" counter return
		iifname != "docker0" tcp dport 443 counter dnat to 172.17.0.2:443
		iifname != "docker0" tcp dport 80 counter dnat to 172.17.0.2:80
[3] ルールセットを統合/適応します。
nano /etc/nftables.conf
#!/usr/sbin/nft -f
# Purge/Flush      #
flush ruleset
# IPv4/IPv6        #
table inet filter {
   chain input {
      iifname lo accept
      # Allow HTTP / HTTPS traffic [needed for IPv6 Discourse access]
   chain output {
      oifname lo accept
# IPv6             #
table ip6 filter {
# Forward Traffic  #
   chain forward {
# IPv4             #
table ip filter {
# Forward Traffic  #
   chain forward {
      jump DOCKER-USER
      oifname "docker0" ct state established,related accept
      oifname "docker0" jump DOCKER
      iifname "docker0" oifname != "docker0" accept
      iifname "docker0" oifname "docker0" accept
# Docker Traffic   #
   chain DOCKER {
      iifname != "docker0" oifname "docker0" ip daddr 172.17.0.2 tcp dport 443 accept
      iifname != "docker0" oifname "docker0" ip daddr 172.17.0.2 tcp dport 80 accept
      iifname "docker0" oifname != "docker0" jump DOCKER-ISOLATION-STAGE-2
      return
      return
   chain DOCKER-USER {
      return
# NAT IPv4         #
table ip nat {
# Docker NAT       #
   chain PREROUTING {
      fib daddr type local jump DOCKER
   chain INPUT {
   chain OUTPUT {
      ip daddr != 127.0.0.0/8 fib daddr type local jump DOCKER
   chain POSTROUTING {
      oifname != "docker0" ip saddr 172.17.0.0/16 masquerade
   chain DOCKER {
      iifname "docker0" return
      iifname != "docker0" tcp dport 443 dnat to 172.17.0.2:443
      iifname != "docker0" tcp dport 80 dnat to 172.17.0.2:80
[4] dockerサービスを再起動した後、Dockerのiptablesルールを無効にします。
nano /etc/docker/daemon.json
   "iptables": false
nft list ruleset
[5] ルールセットを適用します。
nft -f /etc/nftables.conf
これで完了です。確認済み。動作します。誰かの役に立つかもしれません。
@OrkoGrayskull さん、ありがとうございます!
/etc/docker/daemon.jsonfirewall-backendnftables に設定できるようになった今、これに関して何か進展はありますか?そして、たぶん Debian Trixie または Bookworm をお使いなのでしょうか。私は現在これを試しているところです…
/etc/sysctl.confnet.ipv4.ip_forward=1 を設定する必要があることに気づきました。
nftables を使用する Docker のドキュメントには次のように記載されています。
Docker のテーブルを直接変更しないでください。変更は失われる可能性が高く、Docker は自分のテーブルの完全な所有権を期待しています。
そのため、Docker のルールには触れたくないと思っています…
これは現在私が持っているもので、Ansible 経由で追加したいくつかのルールです(このサーバーは Postfix が SMTP を Discourse に転送しているため、ポート 25 が必要です)。
table inet ansible_firewall {
        chain inbound_ipv4 {
                icmp type echo-request limit rate 5/second accept comment "Accept IPv4 rate limited ICMP pings"
        chain inbound_ipv6 {
                icmpv6 type { nd-router-advert, nd-neighbor-solicit, nd-neighbor-advert } accept comment "Accept IPv6 neighbour discovery"
                icmpv6 type echo-request limit rate 5/second accept comment "Accept IPv6 rate limited ICMP pings"
        chain inbound {
                type filter hook input priority filter; policy drop;
                ct state vmap { invalid : drop, established : accept, related : accept } comment "Allow traffic from established and related packets, drop invalid"
                iifname "lo" accept comment "Allow loopback traffic"
                meta protocol vmap { ip : jump inbound_ipv4, ip6 : jump inbound_ipv6 } comment "Jump to chain according to layer 3 protocol using a verdict map"
                tcp dport 22 accept comment "Allow SSH on port TCP/22"
                tcp dport { 80, 443 } accept comment "Allow HTTP on port TCP/80 and HTTPS on port TCP/443"
        chain forward {
        chain output {
                oifname "lo" accept comment "Allow outgoing from loopback interface"
そして、Docker/Discourse からのルールです(このサーバーには IPv6 アドレスがありません)。
table ip docker-bridges {
        map filter-forward-in-jumps {
                type ifname : verdict
                elements = { "docker0" : jump filter-forward-in__docker0 }
        map filter-forward-out-jumps {
                elements = { "docker0" : jump filter-forward-out__docker0 }
        map nat-postrouting-in-jumps {
                elements = { "docker0" : jump nat-postrouting-in__docker0 }
        map nat-postrouting-out-jumps {
                elements = { "docker0" : jump nat-postrouting-out__docker0 }
        chain filter-FORWARD {
                oifname vmap @filter-forward-in-jumps
                iifname vmap @filter-forward-out-jumps
        chain nat-OUTPUT {
                ip daddr != 127.0.0.0/8 fib daddr type local counter jump nat-prerouting-and-output
        chain nat-POSTROUTING {
                iifname vmap @nat-postrouting-out-jumps
                oifname vmap @nat-postrouting-in-jumps
        chain nat-PREROUTING {
        chain nat-prerouting-and-output {
                iifname != "docker0" tcp dport 80 counter dnat to 172.17.0.2:80 comment "DNAT"
                iifname != "docker0" tcp dport 443 counter dnat to 172.17.0.2:443 comment "DNAT"
        chain raw-PREROUTING {
                type filter hook prerouting priority raw; policy accept;
                ip daddr 172.17.0.2 iifname != "docker0" counter drop comment "DROP DIRECT ACCESS"
        chain filter-forward-in__docker0 {
                iifname "docker0" counter accept comment "ICC"
                counter drop comment "UNPUBLISHED PORT DROP"
        chain filter-forward-out__docker0 {
                counter accept comment "OUTGOING"
        chain nat-postrouting-in__docker0 {
        chain nat-postrouting-out__docker0 {
                oifname != "docker0" ip saddr 172.17.0.0/16 counter masquerade comment "MASQUERADE"
table ip6 docker-bridges {
        chain nat-OUTPUT {
                ip6 daddr != ::1 fib daddr type local counter jump nat-prerouting-and-output
ポート 80 と 443 以外のすべては正常に動作しているようです… :roll_eyes:
