Nginx.http.sock not created
The user MaitreCake encountered a ‘Bad gateway’ error with Nginx, caused by the missing /var/discourse/shared/standalone/nginx.http.sock socket file when running Discourse on a Raspberry Pi with Ubuntu 22.04. Despite following a tutorial and trying various fixes—such as setting DOCKER_USE_HOSTNAME: true and adjusting permissions—the socket was not created. The issue was resolved after realizing a forgotten chmod 700 on the container directory MaitreCake had overlooked. pfaffman had suggested trying a simpler setup without a reverse proxy first, which may have helped avoid the issue.
Hello,
I decided to leave phpbb few weeks ago to discourse.
I installed it on a Raspberry pi under ubuntu 22.04.
After numerous attempts to make it work behind Apache I decided to go with Nginx. (I need to run several small websites on my server…)
However, following this tutorial Run other websites on the same machine as Discourse
I have a Bad gateway error with the nginx log giving me a
connect() to unix:/var/discourse/shared/standalone/nginx.http.sock failed (2: No such file or directory)
I am not the first to encounter this issue. Some thread are trully old, others Nginx.http.sock never created did not received proper replies
I did restart several time Nginx (and the docker), saw somewhere that I had to set DOCKER_USE_HOSTNAME: true and I did a chmod -R 777 on /var/discourse/shared/standalone
I am not the biggest specialist around but for the last 25 years I have been able to run different programs on servers (I am pretty new to dockers), I would be delighted to continue on this way if anyone could assist.
Thanks a lot,
PS my yml :
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  ## Uncomment the next line to enable the IPv6 listener
  #- "templates/web.ipv6.template.yml"
  - "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  #- "8080:80"   # http
  #- "443:443" # https
params:
  #db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  #UNICORN_WORKERS: 3
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: 'my.attented_adress.com'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  DISCOURSE_DEVELOPER_EMAILS: 'myemail@adress.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: this_is_set
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: this_is_set
  DISCOURSE_SMTP_PASSWORD: this_is_set
  DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  #DISCOURSE_SMTP_DOMAIN: discourse.example.com    # (required by some providers)
  #DISCOURSE_NOTIFICATION_EMAIL: noreply@discourse.example.com    # (address to send notifications from)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP address key for IP address lookup
  ## see https://meta.discourse.org/t/-/137387/23 for details
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
I would start by following Discourse on a Raspberry Pi | Blog without a reverse proxy.
Thank you very much @pfaffman
It looks like the issue was a forgotten chmod 700 on container.
At the moment, Discourse works behind Nginx on a raspberry 4. I hope it will help the people involved in the other unsolved threads.
