Nginx version pinning
User pacharanero reported that the NGINX version in Discourse was End-of-Life (EOL) following a pentest. Despite updates to the Docker repository, templates were still pinning an older base image, resulting in the continued use of NGINX 1.26.3. david explained that the initial update to 1.28.1 was chosen as the latest ‘stable’ version rather than the ‘mainline’ 1.29.x, and that the template tag bump was intended to address the issue.
However, pacharanero noted that rebuilding the application still yielded NGINX 1.26.3, suggesting the image bump might have been intended for Redis instead. david confirmed this suspicion and investigated with the team. After a follow-up from pacharanero regarding the lack of progress, david committed a new image bump to the repository. pacharanero confirmed that the subsequent rebuild successfully updated NGINX to version 1.28.1.
Not quite a Contribute > Bug but it’s not clear what other category it should go in. It is problematic and isn’t a Contribute > Feature. Possibly Support but I’m fairly sure I know what I’m doing here.
See also: a similar post from 3 years ago Dockerfile in official install instructions uses unsupported version of Nginx
A routine pentest this week found that the version of NGINX that is in use was EOL. It wasn’t possible to exploit it, but it’s been flagged as needing fixing ASAP.
Trying to update Discourse via git pull still hasn’t fixed the issue, because although the Discourse Docker repo is updated, the templates pin the base image as the previous version (discourse/base:2.0.20260109-0020)
Some questions:
  • Why was the pinned version of NGINX so old as to be EOL in the first place? Is there a rationale I’m not aware of?
  • Why has the new version been chosen as 1.28.1, not 1.29.4 (latest as at 2026.01.27) - again is there a rationale?
Generally Discourse seems to be quite keen on keeping all users on a recent version (seems sensible) ie what was tests-passed.
How do I get NGINX updated (ideally without local hackarounds)?
There isn’t any specific reason, it’s just that we hadn’t gone through the update process in a while. You’re right that we should ideally have caught this before it went EOL.
1.28.1 is the latest ‘stable’ version, so that’s what we went with. 1.29.x is the higher-churn ‘mainline’ version, and we don’t currently have a need for any of those new features.
Thanks for raising this. We’ve now finished bumping the tag in the templates, so running another ./launcher rebuild app should give you the new nginx version.
No problem and thanks for speedy response @david !
Sadly this still doesn’t seem to be working. Running a git pull, then ./launcher rebuild app did pull a new image (discourse/base:2.0.20260116-2039) but the image seems to still include nginx 1.26.3:
root@server:/var/discourse# docker exec -it app nginx -v
nginx version: nginx/1.26.3
I’m investigating my end just in case this is some weird container caching issue, but AFAICT it’s simply that that 20260116-2039 base image contains NGINX 1.26.3 still.
Interesting, I’m seeing the same. While we have updated NGINX in the config, it seems like the image bump may have been specifically intended to bump Redis, and not NGINX.
I’ll check in with the team and see about pinning an even newer image version.
Any update on the NGINX version pinning issue? I saw a release of 2026.1.0-latest but AFAICT that does not bump the base image.
We’ve just bumped the image again: Bump base image to `20260129-0023` (#1035) · discourse/discourse_docker@068819b · GitHub
So the next rebuild should give you NGINX 1.28.1
Thanks @david, that’s working now.
