For a theme I want to have distinct category styles and I’m using the category classes for that (like body.category-feedback). When I filter for a tag within a category, this class is not present anymore. I’m still within the category though, so I believe the class should stay.
Edit: It seems to be working on meta. But I get the missing category class on several independent instances. I can’t figure out what’s the common cause so far.
It seems to be caused by the Loading slider component. So when I select a tag and then switch categories, the category class is not updated on the body element. @david?
