אין שליחת דוא״ל פתאומית, DigitalOcean MailJet
Hi,
All of my emails suddenly stopped sending. No clue how this happened, no changes were made.
Sidekiq:
Jobs::HandledExceptionWrapper: Wrapped EOFError: end of file reached
Jobs::HandledExceptionWrapper: Wrapped Errno::ECONNRESET: Connection reset by peer
Jobs::HandledExceptionWrapper: Wrapped Errno::ECONNRESET: Connection reset by peer - connect(2) for "in-v3.mailjet.com" port 587
3 different emails won’t send, on the dashboard, it says “There are 3 email jobs that failed. Check your app.yml and ensure that the mail server settings are correct. See the failed jobs in Sidekiq.”
app.yml:
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 4
  DISCOURSE_HOSTNAME: mydomain.com
  DISCOURSE_DEVELOPER_EMAILS: ‘admin@mydomain.com’
  DISCOURSE_SMTP_ADDRESS: in-v3.mailjet.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: usrname
  DISCOURSE_SMTP_PASSWORD: “psword”
  DISCOURSE_SMTP_DOMAIN: mydomain.com
  DISCOURSE_NOTIFICATION_EMAIL: noreply@mydomain.com
  LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
All emails were working until a random point, didn’t make any changes but errors just started.
Discourse Doctor says “Connection reset by peer This is not a common error. No recommended solution exists!”
Would appreciate any help.
Check your mailjet account. My best guess is an issue with your account.
Hi,
Did you check your firewall settings?
From mailjet side, it seems everything is fine: https://status.mailjet.com/
I would still check if something changed in the configuration.
@pfaffman @Arkshine
Thank you to both for your help, turns out it was a problem with Mailjet. Switched to a different mail provider and it’s working fine ever since.
Thanks!
