Version: v2.6.0.beta2
Setup: Subfolder /forum/discourse setup running on Docker w/ Apache reverse proxy on host /forum/discourse
I have followed the instructions here for the subfolder setup and the installation works fine.
However, some resource URLs are not correctly prefixed and lead to 404s. For example, the URL for the default header logo should be /forum/discourse/images/discourse-logo-sketch.png but Discourse uses /images/discourse-logo-sketch.png.
I’m not quite familiar with the codebase but I think that this should be solved by wrapping application_logo_url with UrlHelper.absolute() here.
I will add to the topic if I find any other instances of the problem. Let me know if this is indeed an issue or if I’m doing something wrong. I’d be more than happy to submit a PR.
app.yml
templates:
expose:
# host has a reverse proxy on these ports
- "8080:80" # http
- "8443:443" # https
params:
db_shared_buffers: "3072MB"
env:
LANG: en_US.UTF-8
UNICORN_WORKERS: 8
DISCOURSE_HOSTNAME: mydomain.com
DISCOURSE_RELATIVE_URL_ROOT: /forum/discourse
DISCOURSE_DEVELOPER_EMAILS: 'info@mydomain.com'
DISCOURSE_SMTP_ADDRESS: mydomain.com
DISCOURSE_SMTP_PORT: 25
DISCOURSE_SMTP_USER_NAME: user
DISCOURSE_SMTP_PASSWORD: pass
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
run:
## https://meta.discourse.org/t/subfolder-support-with-docker/30507
- exec:
cd: $home
cmd:
- mkdir -p public/forum/discourse
- cd public/forum/discourse && ln -s ../../uploads && ln -s ../../backups
- replace:
global: true
filename: /etc/nginx/conf.d/discourse.conf
to: |
rewrite ^/(.*)$ /forum/discourse/$1 break;
proxy_pass http://discourse;
- replace:
to: |
etag off;
location /forum/discourse {
rewrite ^/forum/discourse/?(.*)$ /$1;
- replace:
global: true
to: $http_your_original_ip_header
