여러분 안녕하세요. 처음에는 Support 채널에 이 문제를 게시했지만, 신규 설치 환경에서 여러 번 재현해 본 결과 이제 버그라고 확신합니다. 최신 Discourse 릴리스 이후부터 이 문제를 겪고 있습니다. 재현 단계를 아래에 공유합니다:
일반적인 Discourse 설치 및 설정을 진행합니다 (Ubuntu Server 18.04 LTS와 20.04 LTS 모두에서 동일한 오류가 발생했습니다)
설치가 완료된 후 컨테이너에 들어가서
rake user_actions:rebuild를 실행하면 다음과 같은 오류가 발생합니다:
# rake user_actions:rebuild --trace
** Invoke user_actions:rebuild (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute user_actions:rebuild
rake aborted!
NoMethodError: undefined method `log_topic' for UserActionManager:Class
/var/www/discourse/lib/tasks/user_actions.rake:14:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.2.2/lib/active_record/relation/delegation.rb:85:in `each'
/var/www/discourse/lib/tasks/user_actions.rake:14:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:160:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:125:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:110:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:80:in `run'
bin/rake:13:in `<top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:476:in `exec'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:46:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:34:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => user_actions:rebuild
다른 게시물들에서 비슷한 오류가 발생하면 ./launcher rebuild app을 실행하라는 조언을 봤지만, 그렇게 해본 후에도 여전히 NoMethodError가 발생했습니다.
아무런 조언도 감사하겠습니다. 미리 감사합니다!
