Ieri ho creato un droplet su DigitalOcean 2.2.0 beta1, ma quando provo ad aggiungere un plugin semplicemente con git clone plugin_name si verifica un errore sconosciuto, anche se è valido per ymllint.
Per favore, aiutami: esiste un altro modo per installare il plugin Adsense?
You can use a yaml validator to check syntax issue : http://www.yamllint.com/
Or share parts of your app file here so we can guide you
Don’t forget, you can’t use tab in a yml file, always use space.
4 Mi Piace
o thank you very much i always use tab there thank you for your help i will try it
I try it but agin in git pull it’s saying alredy up to date no
change please help:
# this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
- "templates/web.ssl.template.yml"
- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
- "80:80" # http
- "443:443" # https
params:
db_shared_buffers: "1024MB"
#db_work_mem: "40MB"
#version: tests-passed
env:
LANG: en_US.UTF-8
UNICORN_WORKERS: 4
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: kiit.club
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'my_gmail@gmail.com'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: smtp.sendgrid.net
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: apikey
DISCOURSE_SMTP_PASSWORD: "SG.W_tUjKx2z5btL6ZfuPASSWORD"
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
LETSENCRYPT_ACCOUNT_EMAIL: kiitclubofficial@gmail.com
## The http or https CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- git clone https://github.com/discourse/discourse-adplugin.git
run:
o really really thanks man i try it again and without git pull i just launch ./launcher rebuild app and yes it’s done
thank you very much
3 Mi Piace
