I am unable to add whisper post Using the API. I am passing Whisper field to true in the given go struct.
type Post struct {
TopicID int `json:"topic_id"`
Raw string `json:"raw"`
CreatedAt time.Time `json:"created_at"`
PostType int `json:"post_type"`
Whisper bool `json:"whisper"`
Both, setting whisper to true or post_type to 4 doesn’t seem to work for me. Post is being added but it is not a whisper. However I am able to add whisper through the UI which clarifies that this is not a privilege issue. Can somebody help me here what I am doing wrong?
This seems to be working, but why whisper=true is not returned in response. Instead I see post_type=4 in all the whispers as opposed to post_type=1, does that mean something or not.
Yes, that is a good thing. post_type=4 is a whisper post, which means it was created successfully. If it comes back at post_type=1 then it isn’t a whisper, but just a regular post.
