mrded
(Dmitry Demenchuk)
1
I’m trying to create a Permalink with forums/general-discussion url pointing to a Category.
Then I try to access it - it gives me an error:
AbstractController::ActionNotFound at /forums/general-discussion
The action 'show' could not be found for ForumsController
The problem is with routers:
Discourse::Application.routes.draw do
resources :forums
it processes all /forums/* requests.
I made a pull request here Remove useless routing for ForumsController by mrded · Pull Request #4517 · discourse/discourse · GitHub
Falco
(Falco)
A permalink shouldn’t accept the “/” character because that’s invalid for a location, because its a delimiter.
One permalink as “general-discussion” should work.
Are you in a subfolder install?
mrded
(Dmitry Demenchuk)
3
Thank you for your answer,
I’m using Permalink as redirects from the forum we are migrating from.
And we have to redirect from http://example.com/forums/general-discussion into http://example.com/c/uncategorized
Currently I’m on local development install http://localhost:3000/.
mrded
(Dmitry Demenchuk)
4
The issue has been solved, but still, can you explain why a permalink shouldn’t accept the “/” character?
Am I using it not on purpose? Thanks.
Falco
(Falco)
5
Actually a permalink with a/b/c works, and one with c/xyz also works. Gotta do some digging on this later.
mrded
(Dmitry Demenchuk)
6
