Not public RSS Feed?
Hey guys, just wanted to ask, if it would be somehow possible, to whitelist an host to read not public rss feeds ?
I´m not very comfortable to switch “Require authentication to read content on this site, disallow anonymous access” “false”, but I want to show the latest topics on Atlassian Confluence with the RSS reader macro.
This macro has no means to log in first, so I´m stuck at the moment with the setting "
Require authentication to read content on this site, disallow anonymous access." set to “false”
Is there something I missed ?
Thanks and Greetings,
WS
I think you should be able to use the Discourse RSS Polling Plugin:
You can add RSS feeds through their RSS URL like so:
And it should let you have the Login required setting turned on:
But I’m a bit unsure what you mean – can you clarify if this is what you want? ^^
Hi there, jap, that would probably work, if the oauth2 basic plugin would not directly route the unauthenticated request to the Idp-Portal :frowning:
Therefore the
https://mycommunity.example.net/latest.rss?api-key=xyz
leads me directly to login mask and the rss client spits out an error :frowning:
