This may sound embarrassing, but how do you use a numeric/average poll? It just keeps doing this and I don’t know why.
Just testing:
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
In the discussion “Numeric/Average Poll,” justanotherperson asked for help in using a numeric/average poll, as they were experiencing issues. awesomerobot responded by explaining that the problem was due to the poll’s settings, specifically the step value being too large for the number of choices. They provided examples of how to correctly set up the poll, including using a step value that is reasonable for the range of choices. With this help, justanotherperson was able to get the poll working correctly and thanked awesomerobot for their assistance.
We could probably clarify the text to make this a little clearer…
What you have in your screenshot is:
But you can’t have 11 step with 1 choice, because it would start from 1 and has nothing to increase by 11 because there’s only 1 choice.
Some more examples to demonstrate how these options work:
Starts at 1 (min) and will increase every option by 2 (step) up to 30 (max)
Start at 10 (min) and increase by 10 (step) up to 100 (max)
Start at 1 (min) and increase by 1 (step) up to 5 (max)
Hope that helps!
Yay, it works! Thank you!
