Oauth2-basic plugin and pkce
In a discussion about the oauth2-basic plugin and PKCE under the SSO category, evignola asks whether the plugin supports PKCE, how to enable it, or how to modify the code to implement it. They note that while the omniauth-oauth2 README suggests setting the pkce option to true, no code challenge is being sent to the authorize_url. supermathie responds by acknowledging the request and explaining that PKCE is primarily designed for native apps and SPAs, which cannot securely store client secrets — a concern not applicable to Discourse, as the server holds the secret. They include a humorous GIF to lighten the tone.
Hello all,
I’m new to the oauth2-basic plugin and after reading the docs and source code, I cannot find an answer to my question.
  • Does the oauth2-basic plugin support pkce?
  • If so, how can I enable that?
  • If not, how might I modify the oauth2-basic plugin code to use pkce?
The omniauth github page README says that I should be able to set the pkce option to true in my omniauth strategy. However, I have attempted this change in the oauth2-basic plugin code and no code challenge is being sent to my authorize_url. Any suggestions?
Thanks in advance
Bumping this as a community I assist is requesting support for PKCE.
Prior to being asked about it, I hadn’t yet seen anything about this, but looking through documentation for it it seems the primary driver for this is native apps and SPAs:
Native apps
  • Cannot securely store a Client Secret. Decompiling the app will reveal the Client Secret, which is bound to the app and is the same for all users and devices
  • May make use of a custom URL scheme to capture redirects (e.g., MyApp://) potentially allowing malicious applications to receive an Authorization Code from your Authorization Server
Single-page apps
  • Cannot securely store a Client Secret because their entire source is available to the browser
Neither of which is applicable to this situation; it’s the Discourse server that holds the secret.
Animated GIF
