Octal string exception while importing database
I trying to import a database backup but I’m getting the below error.
I have the latest version (2.5.0.beta4) and rebuild does not work. Please advise.
[STARTED]
'system' has started the restore!
Marking restore as running...
Making sure /var/www/discourse/tmp/restores/default/2020-05-19-193633 exists...
Copying archive to tmp directory...
Unzipping archive, this may take a while...
EXCEPTION: "\x80\x00\x00\x00\x00\x00\x00\x04\xE8\xD3\xA8\x01" is not an octal string
/usr/local/lib/ruby/site_ruby/2.6.0/rubygems/package/tar_header.rb:130:in `strict_oct'
/usr/local/lib/ruby/site_ruby/2.6.0/rubygems/package/tar_header.rb:112:in `from'
/usr/local/lib/ruby/site_ruby/2.6.0/rubygems/package/tar_reader.rb:61:in `each'
/var/www/discourse/lib/compression/strategy.rb:18:in `block in decompress'
/var/www/discourse/lib/compression/tar.rb:26:in `get_compressed_file_stream'
/var/www/discourse/lib/compression/strategy.rb:15:in `decompress'
/var/www/discourse/lib/compression/pipeline.rb:26:in `block in decompress'
/var/www/discourse/lib/compression/pipeline.rb:24:in `each'
/var/www/discourse/lib/compression/pipeline.rb:24:in `reduce'
/var/www/discourse/lib/compression/pipeline.rb:24:in `decompress'
/var/www/discourse/lib/backup_restore/backup_file_handler.rb:69:in `decompress_archive'
/var/www/discourse/lib/backup_restore/backup_file_handler.rb:22:in `decompress'
/var/www/discourse/lib/backup_restore/restorer.rb:42:in `run'
script/discourse:143:in `restore'
script/discourse:159:in `import'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/base.rb:485:in `start'
script/discourse:284:in `<top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:476:in `exec'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:46:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:34:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Trying to rollback...
There was no need to rollback
Cleaning stuff up...
Removing tmp '/var/www/discourse/tmp/restores/default/2020-05-19-193633' directory...
Unpausing sidekiq...
Marking restore as finished...
Notifying 'system' of the end of the restore...
Finished!
[FAILED]
Restore done.
I pushed a fix. It should be available in the test-passed branch in ~15 minutes
https://github.com/discourse/discourse/commit/0a700d81fca8d84c83428e44e6ff31f392535fc1
Thank you, the patch at least gets me past the error, but now I’m running into disk space errors. I’ll let you know if it doesn’t import after I fix the disk space errors.
