Onebox support for readthedocs.org
Hi all,
Very pleased with the onebox support. One limitation seems to be that links to readthedocs.org aren’t oneboxed; eg
Would be great to have this as we experiment with moving the Julia forums over to Discourse; I can help out if someone points me in the right direction.
「いいね!」 1
You have two options here:
  1. implement a custom onebox here: onebox/lib/onebox at main · discourse/onebox · GitHub
  2. (more desirable) add support for opengraph http://ogp.me/ to readthedocs (which would help everywhere) … then you simply whitelist the url.
「いいね!」 4
You should implement OpenGraph at readthedocs.org if you control it, or strongly lobby them to do so.
Lobbying process has begun.
「いいね!」 4
