Onebox Youtube לא מזהה ?t=13m30s אבל כן מזהה ?t=810 - חבר אומר ש-m:s עבד בעבר
סיכום מבוסס בינה מלאכותית
A member reported that Onebox YouTube no longer recognizes URLs with ?t=minutes:seconds (e.g., ?t=13m30s), but still works with ?t=seconds (e.g., ?t=810). kgrier confirmed the issue and found that the M:S format was previously supported in the youtube_onebox_spec.rb code. The issue is likely a regression from the lazy-yt migration, and a PR has been submitted to fix it, as confirmed by jancernik.
Hi Folks,
One of my members pointed out the using minutes and seconds in a YT URL no longer works, he thinks as of a couple months ago. In my testing, he is correct, the video just starts at the beginning. I’ll embed both URL’s here, and let’s see if it’s just my site. - Nope - behaves the same here - I am not a ruby coder, but I looked at the ruby code for youtube_onebox_spec.rb and it looks like the M:S format, along with start and end are accommodated, but neither arguments work on my site.
The M:S format is much easier for folks on mobile to use as the YT app does not provide a way to select start time, the user has to append the ?t= string to the URL when they share it.
Thanks for any assistance. OK, let’s see how these URL’s work here.
Oh, we are at 3.1.0beta4 (f462347e12) and I see 3.1.0beta5 just dropped. I schedule maintenance windows on our site, so won’t be able to run that in right away to see if the update helps this issue.
https://youtu.be/DX3Ag59W68I?t=13m30s
https://youtu.be/DX3Ag59W68I?t=810
2 לייקים
Maybe a regression from the lazy-yt migration @jancernik ?
4 לייקים
Yes, this was a regression. Thanks for the report. This PR should fix the issue:
https://github.com/discourse/discourse/pull/22299
6 לייקים
This topic was automatically closed after 4 days. New replies are no longer allowed.
