Open external links in new tab not working when link is within a quote block
I’ve noticed for a while that links are not opening in new tabs. I thought it was my imagination. I’ve finally managed to replicate it.
I most recently noticed it here: Set up Zulip notifications using the chat integration plugin
And this quoted link opens in the same tab rather than a new one. I thought it might be some browser plugin, but I get the same behavior in an incognito window.
[quote]
:warning: This integration will not be functional until the [Discourse integration is added to Zulip's codebase](https://github.com/zulip/zulip/pull/6201)
[/quote]
Can we repro this @jomaxro?
The Github link in the quote above is certainly not opening in a new tab for me. I’ll do more thorough testing tomorrow.
@sam I can repro this - the quote block appears to be causing the issue. Links work fine when on their own, whether pasted as a raw line, or in the [some text](a link) format. However, when placed inside a `[quote][/quote] all external links fail to open in a new tab.
I don’t know if it’s related or not, but I notice the link inside the above quote isn’t getting the link tracker count indicator.
Here it doesn’t work in a solved inset (in OT):
https://meta.discourse.org/t/configuring-instagram-login-for-discourse/51642?u=pfaffman
Wow I think this bug existed pretty much ever since we launched Discourse.
Fixed per:
This topic was automatically closed after 28 hours. New replies are no longer allowed.
