Shauny
(Shaun Robinson)
May 22, 2024, 10:39am
1
I have a fun idea for some badges, if people contribute greatly to working on my site then I want to be able to add titles directly to their name display, for example a “Professor” title that shows as such:
The normal badge name / title is “Luna Research Team” and the “Professor” is added to the start of my name as a reward as well, just for this badge.
Has anyone made anything like this? Is it possible at all?
Thanks!
Heliosurge
(Dan DeMontmorency)
May 23, 2024, 3:13pm
3
There are a couple of components you could look at to get some ideas. It does look doable.
This theme component allows an admin to add flair to user avatars based on the user’s trust level. Trust level flair displays anywhere on the site that you would normally see group flair. There are a few theme settings to adjust the position of the flair in relation to the avatar.
Basic Examples (with group flair in place)
[examples]
There is also a bottom-right position that will either replace group flair or be replaced by group flair depending on how you set the “group flair always on top” …
