Een avatar over de omslag leggen
Is it possible to overlay an avatar on a banner in a similar way? If yes, then at the same time you need to disable the ability to hide the banner
Can you try this CSS? To be inserted in your theme or a new component CSS.
.user-main:has(.has-background .user-profile-image) {
    $avatar_size: 144px;
    $avatar_margin: 20px;
    $avatar_border_size: medium;
    .user-profile-avatar {
        position: absolute;
        top: calc(-#{$avatar_size} / 2 - $avatar_margin);
        left: $avatar_margin;
        img.avatar {
            background: var(--secondary);
            border-width: $avatar_border_size;
    .primary-textual {
        margin-left: calc($avatar_size + $avatar_margin * 2);
What is your theme? It might need some adjustments.
FKB Pro theme.
How can I add or change css here?
The recommended way is to create a new component, attach it to your theme, then you can Edit CSS/HTML there. :+1:
Ty! It’s working
But if the cover is hidden, the avatar will not be displayed either. How can I disable the ability to hide the cover?
I’ve updated the CSS above, can you try again?
It looks good on my side now:
:partying_face:
