Sovrascrittura del pulsante "toggle reply"
This is a repost from: Could we get the link to post replies in mobile view? - #12 by Ellibereth, but it probably belongs here in Development and not in that topic.
I’m trying to modify the “toggleReplyAbove” action, to show a modal of the replied-to-post on mobile instead of jumping to the post (why we’re doing this is described in the above topic).
It looks to be in the post widget, but if I use the following code to try and replace the action I don’t see any effect - nothing is printed to console and it behaves as normal:
api.attachWidgetAction('post', 'toggleReplyAbove', () => {
    console.log('toggle triggered');
In the post widget code, it looks like the toggleReplyAbove function is defined inside the created widget post-article , but that doesn’t seem to be modifiable with attachWidgetAction since the following code trying to modify that widget results in the error Uncaught TypeError: Cannot read property 'class' of undefined :
api.attachWidgetAction('post-article', 'toggleReplyAbove', () => {
I’m able to overwrite the “like” action on post-menu fine as described here Updating Discourse Plugins, taking the first step - #9 by eviltrout. Where should I be attaching the widget action to overwrite the toggleReplyAbove action?
Looks like this was a bug in the plugin api:
https://github.com/discourse/discourse/commit/6fec4982d903cbb088f95b5dcae7b67f52a90e99
The issue here is that we were only looking in the container for the widget class, which only works if it’s the only widget exported by a javascript file.
This patch allows us to look up any widget registered with that name.
