What would you like done?
I have a forum powered by Discuss on Modx cms (Discuss 1.2-pl | MODX).
I want to create to export the forum ( users, categories and posts ) to Discourse.
I can provide a local install of Modx/discuss from Mamp on Mac.
Optional work:
Even if the final result would be importing datas to Discourse. I’m also interested in customizing Vanilla Porter. (https://open.vanillaforums.com/addon/porter-core)
Vanilla export file works like a charm with Discourse. And I am sure I will be able to re-use the script the future.
When do you need it done?
In a week max.
What is your budget, in $ USD that you can offer for this task?
$250-550. Of course, it is negotiable, but depends on your experience.
Bear in mind you’ll have to work locally. I won’t give you access to a live server.
Thanks
