[BETAALD] bbPress-site migreren naar Discourse
What would you like done?
I have an old bbPress forum which you can see here that needs to be migrated to Discourse hosted on DigitalOcean.
The current forum uses "GD bbPress Attachments: for attachments that need to be migrated as well.
On top of that, I will need to have redirects from the old forum to the new under a subdomain. - forums.colorlib.com/old-forum-thread-urls
Everything must be seamless at the end. All data migrated including attachments, as well as proper redirects that users wouldn’t notice the change.
When do you need it done?
Yesterday. But in all seriousness, any time in the next week or two is fine since it is not a major project it shouldn’t take too long.
What is your budget, in $ USD that you can offer for this task?
$500. Can be adjusted if there is a good reason for that.
I can help out with that, though I’m not sure whether your attachments are the ones supported by the importer. Please fill out Redirecting…, which will give me a bit more information about your project.
Thanks
Thanks, forwarded all the data.
