What would you like done?
Been having regular login issues for my users. I mentioned here:
My users just started seeing “403 Unknown Error” when trying to log in. I followed these instructions - but I’m now getting an error in the admin settings: " * Your website is using SSL. But [force_https](https://movermaker.com/admin/site_settings/category/all_results?filter=force_https) is not yet enabled in your site settings."
I am using the Digital Ocean app setup with nothing custom, and ‘v2.0.0.beta2 +170’. Is this because I’m using a beta version?
The issue seems clear to responders but not sure on a solution. As mentioned there I executed the suggested changes and it hasn’t solved anything.
Would like someone to fix this + outline how it was done so I don’t run into similar issues in the future.
Using Digital Ocean Ubuntu Discourse 2.0.20170531 on 16.04, behind Cloudflare.
When do you need it done?
ASAP, this has been a real problem for our early community.
What is your budget, in $ USD that you can offer for this task?
Not sure, hoping this is a pretty quick fix. Will pay for the time spent. Estimates welcome!
mbcahyono
(Muhlis Cahyono)
April 6, 2018, 6:44pm
Have you tried to disable cloudflare?
pfaffman
(Jay Pfaffman)
April 6, 2018, 6:48pm
3
That’d be my recommendation. I’m not very familiar with cloudflare, and it’s very clear from reading here that lots of other people aren’t either.
@cloudunicorn , if you’d be willing to disable Cloudflare, at least long enough to see if that’s the problem, see Fix Your Broken Site – Literate Computing, LLC
Cheers guys, thanks.
I stopped sending through Cloudflare and did the Lets Encrypt setup, and site seems to work post changes, so asking users to log in and see if issue persists.
Appreciate the suggestions.
system
(system)
Closed
May 6, 2018, 9:40pm
5
