用户邀请的永久推荐链接
Currently developing a referral plugin that pays for sign-ups. We’ve noticed that there is no option for members to generate a permanent referral (signup) link. The only way is to do it individually via adding an email. I was thinking, why have such a cumbersome invite process? Why not provide an (example) example.org/ref?=93181 link which a member can share across the web over and over again? Not having the ability to do so, restricts the possibilities of having blogs/sites write about your site/service/forum, providing that the webmaster of the discourse instance is providing incentives for signups (tons of sites do this).
Is there a chance of permanent invite links? Or am I missing something obvious and the feature is implemented already?
3 个赞
Looking for this?
2 个赞
If I am understanding this correctly, the plugin still requires an individual URL to be created for each invite, which isn’t what I meant.
Prepare Invitation Links from Invite Token
The Invitation URL will be like:
http://discourse.example.com/invite-token/redeem/TOKEN?username=USERNAME&email=EMAIL&name=NAME&topic=TOPICID
Replace following fields:
    • discourse.example.com with the URL of your Discourse instance.
    • TOKEN with one of the 200 Invite tokens you just generated.
    • EMAIL with the email of user you want to invite
  • USERNAME with the desired username of invited user
  • NAME with the first name of invited user
  • TOPIC with the id of the topic to direct the user to after joining
(*) these fields are required!
My idea was to have a set unique URL for each member that he can share to invite. The URL doesn’t change, doesn’t have a limited amount of tokens, and doesn’t require editing for each invite. Having such an URL gives discourse site owners a tool to promote their sites better (if they’re offering incentives for signups).
Would simply using a link like this work for you?
yourforum.com/signup
1 个赞
Does that track who referred the person who signed up to the site?
To be clear that I understand you, you’re looking for something like
https://meta.discourse.org/signup?u=mittineague
so that my account would be associated with any that used that link to join?
Currently, because I have established some trust here, it can be inferred that I can be trusted to invite those that I feel can be trusted enough to not need to go through the initial New member limitations and they can start off with Trust Level 1 abilities. i.e. I’m vouching for them.
A “generic” invite link would open the possibility that anyone could use the link, regardless of whether or not they should indeed be trusted.
How might you propose that risk be prevented?
1 个赞
Yes, that would be it.
Why not have both? Don’t you think it would be great to give sites incentives to promote your forum? A generic link would allow webmasters to place links in their articles, so you can track and reward signups accordingly. At least, that’s my plan. I was hoping that this generic link would be available, but it looks like I have to hire someone to get it done.
Not all forums are set up in the same way. My instance has a phone verification system for all new signups (can’t join until you confirm your phone number via TXT pin and email), which cuts down on 90% of problems associated with spam and whatnot. So to me, that risk is irrelevant. But I do see your point of view and see how it may be a problem for some. I guess people invited with the generic link start at TL0 while custom invites start off higher? That would be a solution, no?
Thanks for replying.
Yes, I think that could work. Unfortunately at the moment it would require a plugin which as of yet does not exist.
1 个赞
What you really want here is more of a traditional referral link system than what we call invite here in Discourse. I suggest renaming it so you don’t clash with the existing feature.
A plugin that saves a cookie from anons that visits a URL (forum.example.com/?referral=falco), and that checks for the cookie value on user creation and gives a point for the referral value is certainly doable.
3 个赞
Good to hear! Will forward this to my dev then :slight_smile:
1 个赞
