PG::UndefinedTable: ERROR: relation "translation_overrides" does not exist
I have cloned master and in trying to run migrations i get this error:
ActiveRecord::StatementInvalid: PG::UndefinedTable: ERROR: relation “translation_overrides” does not exist
I see that a topic was created for this last November and seemingly fixed so i’m wondering what coudl be the cause?
ActiveRecord::StatementInvalid: PG::UndefinedTable: ERROR:  relation "translation_overrides" does not exist
remote:        LINE 5:                WHERE a.attrelid = '"translation_overrides"':...
remote:        ^
remote:        :               SELECT a.attname, format_type(a.atttypid, a.atttypmod),
remote:        pg_get_expr(d.adbin, d.adrelid), a.attnotnull, a.atttypid, a.atttypmod
remote:        FROM pg_attribute a LEFT JOIN pg_attrdef d
remote:        ON a.attrelid = d.adrelid AND a.attnum = d.adnum
remote:        WHERE a.attrelid = '"translation_overrides"'::regclass
remote:        AND a.attnum > 0 AND NOT a.attisdropped
remote:        ORDER BY a.attnum
thanks
Is that a dev setup? If so, then run “rake db:drop db:create db:migrate” again.
production but getting it to run on heroku (i realise that heroku is not the ‘supported’, ‘recommended’ setup :slight_smile: ). despite that, do you have any ideas? thanks a lot
こんにちは皆さん、これは Migration error on fresh startup running in k8s cluster と同じ問題のようです。また、公式の standalone.yml テンプレート を使用した純粋な Discourse ランチャー環境で、デプロイ時にこの問題を再現することができました。
$ ./launcher rebuild app
I, [2021-05-27T10:53:27.612150 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake plugin:pull_compatible_all'
I, [2021-05-27T10:53:30.072954 #1]  INFO -- : docker_manager はすでに最新互換バージョンです
I, [2021-05-27T10:53:30.073194 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
2021-05-27 10:53:32.977 UTC [4354] discourse@discourse ERROR:  文字位置 454 で、リレーション "translation_overrides" が存在しません
2021-05-27 10:53:32.977 UTC [4354] discourse@discourse STATEMENT:  SELECT a.attname, format_type(a.atttypid, a.atttypmod),
	       pg_get_expr(d.adbin, d.adrelid), a.attnotnull, a.atttypid, a.atttypmod,
	       c.collname, col_description(a.attrelid, a.attnum) AS comment
	  FROM pg_attribute a
	  LEFT JOIN pg_attrdef d ON a.attrelid = d.adrelid AND a.attnum = d.adnum
	  LEFT JOIN pg_type t ON a.atttypid = t.oid
	  LEFT JOIN pg_collation c ON a.attcollation = c.oid AND a.attcollation <> t.typcollation
	 ORDER BY a.attnum
警告: oid 19 の型 "name" に対して型キャストが定義されていません。今後の変更に対して安全であるためには、この型を明示的に TEXT にキャストしてください。
> テーマとカラースキームのシードを開始
I, [2021-05-27T10:53:49.976589 #1]  INFO -- : == 20000225050318 AddSchemaMigrationDetails: 移行中 ========================
